Zvezda 1/72 C-130H Hercules
  • outrunner
    • Apr 2019
    • 2420
    #31
    Lovely job Andy.
    Andy.
      • 22770
      #32
      Great work so far Andy, looking very good.
        Thanks all.
        I've been putting the engines together today. After doing all the suggested internal painting I've realised you're going to see a big fat zero of any of it without an endoscope. Much like the interior now that I've closed it up.
        Good job I enjoyed doing it anyway :smiling5:
          You enjoying it is what counts, really. Of course, I find it helps with the enjoyment if something actually remains visible afterward …
            Indeed Jakko :smiling5:
            Well, it isn't getting any smaller! Wings are only dry fitted at the moment but it's overhanging my makeshift paint bench by a fair way.
            [ATTACH]406869[/ATTACH]
            And there's a minor technical hitch with the nose weight. I weighed out the required amount of Zero Gravity, but can't get it all in! I've packed it as tightly as I can, even removing a bit here and there as the nosecone wouldn't fit.
            [ATTACH]406870[/ATTACH]
            Luckily I've already added a bit of lead strip under the cockpit, and I think there's an area in the front gear bay that can be packed and hidden with a bit of plastic card.
            I'll add the rest of the tailplane and do the see-saw test before panicking too much. If all else fails I'm going to pose it with the loading ramp down anyway, so that should prop it up nicely.
            • Fernando N
              • 2448
              #36
              Looking very good Andy, neat interior hope the weights work out.
                • 18903
                Liking this build. It’s a big lad isn’t it. How are you going to display it?
                  Thanks Fernando.
                  I've no idea Tim! I'm seriously running out of room already. Will probably end up junking some of my older stuff
                  • outrunner
                    • Apr 2019
                    • 2420
                    #39
                    Coming along nicely Andy, I have used chopped up car balance weights mixed with epoxy in the past for balancing modelaircraft.
                    Andy.
                      Thanks Andy.
                      Yes, I have a collection of those too. Scrounged from the tyre fitting bays at work lol.
                      • rtfoe
                        • 9086
                        #41
                        Andy, the dreaded see-saw test can be a little stressful so to avoid that I'd have stuffed the cheeks of the landing bay, the roof of the cockpit and front loading bay...areas that are not within eye-shot of any openings. Still your escape plan of the loading bay door will work nevertheless.
                        At this point it looks like a 'Herky' and neatly done. :thumb2:
                          Thanks Richard. I've actually been fixing the weight issue this morning.
                          I made a small compartment with card at the front of the landing gear bay. I added a few strips of lead (~7g) then the rest of the Zero Gravity I'd weighed out. Coupled to what's already under the cockpit I think that should be plenty.
                          [ATTACH]406908[/ATTACH]
                          With the bay door in place (which is closed once the gear is down) no one would be any the wiser :smiling3:
                          [ATTACH]406909[/ATTACH]
                            • 18903
                            Nice hack on the weight there Andy.
                              Good fix
                              • rtfoe
                                • 9086
                                #45
                                Well done on that Andy....test should be positive.
