Spitfire MarkVI
  • saguy
    • Feb 2011
    • 570
    Spitfire MarkVI
    hi there ..my next project is the spitfire mark vi (hasegawa 1/32).... need a little help with the paints required here:
    as per the paint chart the colours are
    upper surface ..khaki green and ocean grey
    lower surface ..medium sea grey
    cockpit colour ... not quite sure what to use here as the plans do not specify any colour
    Has anyone got the references for either tamiya or life colour paints that I should be using using
    tx a lot
    lindsey
    • 18266
    Tamiya have only spray cans with the correct colours, that I know, if you are airbrushing you will need to start mixing.:smile10:
    The rattle can colours are:
    AS30 for the Dark Green
    AS31 for the Ocean Grey
    AS32 for the Medium Sea Grey
    cock pit. Grey Green XF71 or there abouts
      I used Xtracrylix on my Spitfire upper surfaces and they worked out ok. They have the official colours too.
      HTH
      Stuart
      • stona
        • Jul 2008
        • 9889
        Ian has named the colours correctly. Lifecolor don't do exact matches though they do a Dark Green and a Medium Sea Grey. You could always do a 7:1 MSG to Black mix for your Ocean Grey,as that's what the RAF originally did.
        The Interior Grey/Green is not a million miles from Humbrol 72.
        • saguy
          • Feb 2011
          • 570
          hi all ...some pics of the cockpit ... no extras just straight out the box as is ...also found the model in another gallery with a little write up of the build ....rgds lindsey
          [ATTACH]42488.IPB[/ATTACH]
          [ATTACH]42489.IPB[/ATTACH]
          [ATTACH]42490.IPB[/ATTACH]
          [ATTACH]42491.IPB[/ATTACH]
          [ATTACH]42492.IPB[/ATTACH]
          [ATTACH]42493.IPB[/ATTACH]
          [ATTACH]42494.IPB[/ATTACH]
          • saguy
            • Feb 2011
            • 570
            some pics ...sadly the rearview mirror came off and is in the carpet somewhere .hno:... seemed appropriate to park it next to the emil on the shelf (not sure if they would have ever met in combat) ....rgds ....lindsey
            [ATTACH]43584.IPB[/ATTACH]
            [ATTACH]43585.IPB[/ATTACH]
            [ATTACH]43586.IPB[/ATTACH]
            [ATTACH]43587.IPB[/ATTACH]
            [ATTACH]43588.IPB[/ATTACH]
              you have doned nice job
              well done
