Airfix 1/24 mosquito nfII/fbvl
  • peterairfix
    • Jul 2012
    • 11083
    #31
    More work done on the engines Click image for larger version
ID:	1144232Click image for larger version
ID:	1144233Click image for larger version
ID:	1144234Click image for larger version
    • peterairfix
      • Jul 2012
      • 11083
      #32
      More added on the engines witch are turning out to be a kit in itself Click image for larger version
ID:	1144314Click image for larger version
      • adt70hk
        • Sep 2019
        • 10438
        #33
        Great work Peter.
        ATB.
        • peterairfix
          • Jul 2012
          • 11083
          #34
          A few more pipes and the engine mounts attached Click image for larger version
ID:	1144362Click image for larger version
ID:	1144363Click image for larger version
          • ozdell
            • Apr 2020
            • 365
            #35
            A few more pipes and the engine mounts attached [ATTACH=CONFIG]n1144362[/ATTACH][ATTACH=CONFIG]n1144363[/ATTACH][ATTACH=CONFIG]n1144364[/ATTACH]
            Hi Peter, wow that 24th scale Mosquito a huge model double the size of the spitfire,, actually my favourite British twin fighter of WW2 are you going to model the fighter version , I had a 72nd scale as what I would do, look forward to lot of pics, the Merlin motor I built is different to your build hard to build made a few mistakes along the way . Tony
            • peterairfix
              • Jul 2012
              • 11083
              #36
              Engine's finished for the moment and I have started on the the landing gear Click image for larger version
ID:	1146247Click image for larger version
              • ozdell
                • Apr 2020
                • 365
                #37
                Engine's finished for the moment and I have started on the the landing gear [ATTACH=CONFIG]n1146247[/ATTACH][ATTACH=CONFIG]n1146248[/ATTACH]
                Coming along nicely the landing gear , Tony
                  • 18944
                  Just caught up on this. Coming on well Peter. This is modelling on an epic scale.
                  • peterairfix
                    • Jul 2012
                    • 11083
                    #39
                    I have now started working on the the undercarriage and installing the engines. Click image for larger version
ID:	1146309Click image for larger version
ID:	1146310Click image for larger version
ID:	1146311Click image for larger version
ID:	1146312Click image for larger version
                    • peterairfix
                      • Jul 2012
                      • 11083
                      #40
                      I have finally got everything together so I now have something that resembles an aircraft and I will be going all buttoned up. Click image for larger version
ID:	1146355Click image for larger version
                        Engines look good installed Peter, well worth the effort.
                        • scottie3158
                          • 14243
                          • Holbeach
                          #42
                          Peter,
                          Looking very nice mate. Your going to need a big shelf :smiling3:
                          • peterairfix
                            • Jul 2012
                            • 11083
                            #43
                            Nearly there yesterday I constructed and fitted the tail wheel installed the undercarriage doors, fitted the cannons and nose machine gun's and nose. Click image for larger version
ID:	1146433Click image for larger version
ID:	1146434Click image for larger version
ID:	1146435Click image for larger version
ID:	1146436Click image for larger version
ID:	1146437Click image for larger version
                            • peterairfix
                              • Jul 2012
                              • 11083
                              #44
                              As I am going with the buttoned up version here's the work so far. Click image for larger version
ID:	1147476Click image for larger version
ID:	1147477Click image for larger version
ID:	1147478Click image for larger version
                              • scottie3158
                                • 14243
                                • Holbeach
                                #45
                                Peter,
                                Looking very nice so far.
