Pete's tiny Typhoon
  • stillp
    • 8097
    • Pete
    • Rugby
    Pete's tiny Typhoon
    Sorry I haven't been posting much recently, I haven't felt much like modelling. My eyesight has been playing up, and my hands shaky, so what could be a better choice that this:
    Yes, 1/144, and just about 4 inches long.I blame Tony (Yak Face), because he made this scale look easy!
    2 schemes, one German, but I'll be doing the 3 Squadron version from Coningsby. Whoops! Photographed the wrong one! Plenty of underwing stores to play with.
    Lots of decals too:
    A couple of sprue photos:
ID:	1140812Click image for larger version
    Nicely moulded, but has some really tiny parts, like the control column shown above. This is the two-seater Typhoon, so there are two of them. The clear sprue isn't so good:
    Doesn't really show in the photo, but the lower edge of the canopy has a sort of rippled effect. That should stop anyone seeing the mistakes in the cockpit!
    The first few stages are the construction of two cockpit tubs, and fitting decals for the IP and the side consoles.
    They look better in real life, honest.
    Fuselage halves went together perfectly, most of the join being hidden on the top by the ridge, that's provided as a separate part. There's a small part (looks just like the sidelight on my TR4A!) to be fitted to the front LH side of the fuselage, (part 33 here)
    but there's no location for it, and it was clearly going to be tricky to hold, so I left it attached to a small section of sprue, glued it to the fuselage:
    then cut the sprue off after the glue had dried.
    That'll do for tonight I think. Wings tomorrow maybe.
    • 15746
    Hi Peter
    Well there's a lot there for something only 4 inches long. Looks as if you're off to a fine start.
      • 18932
      Good stuff so far Peter. Looks like there’s more decals than parts.
      • BattleshipBob
        • 6804
        • Bob
        • Cardiff
        1/144 Pete, good god i could not find the box :nerd:
        Hope you feel better soon
        Bob
        • PaulTRose
          • Jun 2013
          • 6509
          • Tattooine
          good luck
          only done a couple in that scale and were fun despite the size
          Per Ardua
            • 22771
            Cracking start.
            • yak face
              • Jun 2009
              • 13854
              • Tony
              Brilliant start pete ! This looks like another beautifully detailed 1/144 kit from Revell . The decal sheet would put many a 1/48 to shame , although some of those stencils must be TINY! This looks like its going to go on my ‘to get‘ list , cheers tony
              • spanner570
                • 15439
                ...just trying to figure out just where that small, one piece decal goes?
                You will no doubt try and fool me by writing they are all diddy separate ones!
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  HI Pete looks like it gonna be a great build an i'll be followin an yes i know what these small 1/144 scale kits are like as i built over 50 of these kits but in the tomcats an other planes for my nimitz carrier an these kits may be small but they look good
                  chris
                  • stillp
                    • 8097
                    • Pete
                    • Rugby
                    Still struggling with some health issues as well as a poorly cat, but I've got the canopy on, masked and the interior framing colour on:
                    Made a start cleaning up the fuel tanks, Taurus pod and Storm Shadow.
                    There are some Sidewinders as well as AMRAAM, Iris-T and Meteor missiles, so lots to do yet. Does anyone have any tips on how to hold the missiles for painting without the mounting points getting clogged with paint?
                    • langy71
                      • 1950
                      • Chris
                      • Nottingham
                      If it helps I tend to put a cocktail stick into the mounting holes, then pull it out after I've finished with paint and weathering..
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        [ATTACH=CONFIG]n1141414[/ATTACH]
                        [ATTACH=CONFIG]n1141415[/ATTACH]
                        HI Pete regards painting misseles normaly now say if its a sidewinder but one of the newer missles they are normally blue with black tip from what ive seen so hold the tip while the main part of the missles bein painted then when paint dry then paint the tip black simple
                        chris
                        • stillp
                          • 8097
                          • Pete
                          • Rugby
                          Yes, I'd do that if they had mounting holes, but they're too small so the mountings are just tiny grooves, on the Sidewinders about 2 mm long. The missile body is only 0.7 mm diameter.
                          chris
                          OK for the Sidewinder and AMRAAM Chris, but the others don't have a different colour on the tip.
                          Anyone know what a 3 Squadron Typhoon would carry?
                          • scottie3158
                            • 14221
                            • Holbeach
                            Pete,
                            That's a neat looking build mate.
                            • stillp
                              • 8097
                              • Pete
                              • Rugby
                              Just found this on jetwashaviationphotos.com " The 'Southern QRA' (Quick Reaction Alert) is part of the UK Air Defence System and previously the domain of the Tornado F.3 fleet. Taken over by 3 Sqn at RAF Coningsby on 29th June 2007 with the Typhoon F.2, the standard QRA weapons fit is two x 200 gallon (1,000 ltr) drop-tanks, four x Raytheon AIM-120 Advanced Medium Range Air to Air Missiles (AMRAAM) and four x AIM-132 Advanced Short Range Air to Air Missiles (ASRAAM). " No ASRAAMs in the kit though so I'll use some of the others.
