Hawker Hurricane Mk1, 1/72, Airfix
  • PaulTRose
    • Jun 2013
    • 6465
    • Tattooine
    wasnt going to do another plane for a bit but i need something to keep me ticking over whilst the T-60 is at the 'getting there' stage and this appealed.....another for my WW2 RAF long term project
    [ATTACH]411844[/ATTACH]
    [ATTACH]411845[/ATTACH]
    Per Ardua
  • Steven000
    • Aug 2018
    • 2828
    • Steven
    • Belgium
    Always nice to see these warbirds comming together, will be following along :thumb2:
    Have fun
    • adt70hk
      • Sep 2019
      • 10409
      Will be interested to see how this turns out, as I have this one in the stash.
      ATB.
      • PaulTRose
        • Jun 2013
        • 6465
        • Tattooine
        going together ok, but still needing some filler in places, but infinately better than the Strikemaster
        [ATTACH]412110[/ATTACH]
        Per Ardua
        • Defiant911
          • Feb 2020
          • 640
          [ATTACH=CONFIG]n1142310[/ATTACH]
          [ATTACH=CONFIG]n1142311[/ATTACH]
          This one is on my list to do also. Will compliment the Lancaster and spitfire I already completed.
          will watch this one progress.
          • colin m
            • 8755
            • Colin
            • Stafford, UK
            Nice start. I should build more 1:72 before the eyes fail. You get a fairly quick, satisfying result in this scale, mostly.
              • 15704
              Hi Paul
              So often the Hurricane takes a back seat to the Spitfire and yet I think I read somewhere that there were more of them. 1/72 is a nice scale for planes and vehicles are readily available if you fancy making a dio. I'll enjoy seeing how this goes on.
              • adt70hk
                • Sep 2019
                • 10409
                Originally posted by Jim R
                Hi Paul
                Hi Jim
                I think you're right, at least I remember reading more than once that Hurricanes responsible for more kills in the battle of Britain than Spitfires.
                Also read somewhere that apparently Hurricanes could out-turn Spitfires and by a lot and Spitfires could out-turn 109s. If I recall correctly, the turning circle for a 109 was quoted as 880 yds, Spitfire 800 yards and a Hurricane 600 yards. I have no idea what speeds these turning circles were being made at but my assumption would be that the slower you are the tighter the circle.
                ATB.
                • stillp
                  • 8093
                  • Pete
                  • Rugby
                  I believe one of the problems with the Hurricane was that the early ones didn't have variable-pitch props, so if the pitch was set for good flight performance they could barely get off the ground. They accounted for a lot more 'kills' than the Spitfire, largely because they were a more stable gun platform. The thick wing allowed a wide variety of armament to be fitted. The Hurricane was also a lot easier to build and to maintain that the Spit.
                  • PaulTRose
                    • Jun 2013
                    • 6465
                    • Tattooine
                    Hi Paul
                    lol....you should look up my RAF Daguerre thread......this Hurri will be part of that
                    Per Ardua
                    • scottie3158
                      • 14201
                      • Holbeach
                      Paul,
                      Nice start.
                      • spanner570
                        • 15404
                        Paul, I made this self same kit for the' Starter Set G.B.' in 2019.
                        A cracking build. No problems whatsoever. The decals were first class too.
                        Enjoy.
                        • PaulTRose
                          • Jun 2013
                          • 6465
                          • Tattooine
                          so a question to the masses
                          will this do?..........took the masking off and just think it looks a little too much brown but i dont want to try spraying in any extra green and risk ruining the whole thing
                          [ATTACH]412728[/ATTACH]
                          Per Ardua
                          • stillp
                            • 8093
                            • Pete
                            • Rugby
                            Maybe a little too much on the port wing, but I'd leave it, it looks fine. It'll look even better with the roundels on.
                            • spanner570
                              • 15404
                              Paul, I think Pete is right. The roundels will help balance things out. Not much future in messing with the colours at this stage.
                              Anyway, I think it looks fine as it is without even thinking about any alterations.
                              Ron
