[ATTACH]411986[/ATTACH] Some of the strips.
1/9th Scale B-17G Bomber.
[ATTACH]411987[/ATTACH] Now the beginning of the strip planking.Attached FilesComment
[ATTACH]411988[/ATTACH] As you continue, you will eventually come to this. It's inevitable.Attached FilesComment
[ATTACH]411989[/ATTACH] Cut out the approximate piece to fit.Attached FilesComment
[ATTACH]411991[/ATTACH] Created some balsa dust to be used as filler.Attached FilesComment
[ATTACH]411992[/ATTACH] The filler has been applied using CA glue.Attached FilesComment
[ATTACH]411993[/ATTACH] Applying Red Devil lightweight spackle over entire nacelle.Attached FilesComment
[ATTACH]412001[/ATTACH] Now the outline for the main landing gear.Attached FilesComment
