First build in 35 years...
  • Charlie Delta Foxtrot
    • Jan 2021
    • 383
    #16
    Undercarriage assembly, as pointed out earlier, was fiddly and I have a warped wing strut on the left which is pushing my wheel bay about a bit. Some hack and slash and Ive sorted it. Also the engine covers don’t fit great on this model, Airfix Lancaster BII. Anyway, we are where we are, flaps down, wheel bays open, that’s it for today I think.
ID:	1142865Click image for larger version
ID:	1142866Click image for larger version
ID:	1142867Click image for larger version
    • PaulTRose
      • Jun 2013
      • 6509
      • Tattooine
      #17
      coming together nicely
      dont you already have a Lanc thread for this?
      Per Ardua
      • AlanG
        • 6296
        #18
        The threads have now been merged together. Russel. Please keep all updates on this build in this thread.
        Many thanks
          • 15746
          Hi Russell
          Undercarriage looks good. I have limited experience of building planes but the undercarriage often seems fiddly and fragile.
            • Jan 2021
            • 383
            #20
            Many thanks
            Thanks. Wasn’t sure if it needed to be in a certain section as a wip. Shall stick to this thread :-)
              • Jan 2021
              • 383
              #21
              Update Saturday! My filler arrived; Tamiya putty, good stuff so have closed gaps on the wings and for the ill fitting engine covers. Sanding this plane has been difficult as you are always at risk of knocking something else off. In hindsight I should have waited to attach tail, bomb doors, weapons turrets etc. I’ve also had a problem with my windows and canopies. I saw a tip to use pva glue but they have simply fallen in or, as I had to resort to other glue I have fogging. I know have ammo mig’s ultra glue and had to use the spare bomb aimers glass and the incorrect side panels for the main canopy BUT, they are at least clear. I also bought some Micro Krystal Klear so will replace the missing windows with it after painting. Live and learn.Click image for larger version
ID:	1143258Click image for larger version
ID:	1143259Click image for larger version
                • 15746
                Hi Russell
                Fine progress. I think we have all attached parts too soon in the build and then knocked them off a few times. Wing mirrors, aerials, lamps, undercarriages etc. That Micro Krystal Klear is good stuff.
                • colin m
                  • 8770
                  • Colin
                  • Stafford, UK
                  #23
                  Looks like you are doing a great job here. A BII as well, I don't think I've seen one of these Hercules engine variants built.
                    • Jan 2021
                    • 383
                    #24
                    Much progress! Now just need to wait for it to be warm enough to varnish and then get some decals on.Click image for larger version
ID:	1143861Click image for larger version
ID:	1143862Click image for larger version
                      Nice work!
                      Re: sticking clears, try using Krystal Klear for this, since you have it already. You’ll need to be patient and careful, but it should allow you to glue without damage.
                        • 15746
                        Hi Russell
                        Someone has been busy. Looking good. The decals will bring it to life.
                          • Jan 2021
                          • 383
                          #27
                          Originally posted by Archetype
                          Nice work!
                          Thanks. I only realised afterwards that Krystal Klear could also be used as adhesive, bought it to fill in my missing windows, so I bought Ammo’s Ultra Glue too...’all the gear...’ I’ve honed it though and in the end; it has worked well. No more fogging! Thanks.
                            • Jan 2021
                            • 383
                            #28
                            Originally posted by Jim R
                            Hi Russell
                            Cheers Jim! Going to use some decal set and fix. Hope no silvering...
                              • Jan 2021
                              • 383
                              #29
                              Update! I ruined the underside with poor glossing but managed to bring it back. I also lost a wheel so had to wait for Eduard replacements. Just a couple of bits to do now. Click image for larger version
ID:	1144809Click image for larger version
ID:	1144810Click image for larger version
                              • Mini Me
                                • Jun 2018
                                • 10711
                                #30
                                That has turned out nice Russell. :thumb2: Rick H.
