Hi,
I forgot the other angle of the cockpit showing the dash board and instrument panel which was a cut out of a photostat copy from an instruction sheet. It was quite stark so I toned the white details down with a tint of diluted black and picked out three switches in red. You will notice the circular disc with a handle behind the seat comes from a German Flak 37 elevating wheel.
For the exterior there were some mods and detailing for the front and back engine nacelle which was previously flat and a hole for the prop shaft.
Underside vents on either side of the front wheel well for the front engine...
Also vents for the rear engine compartment replacing the solid moldings.
Then there is the light glare deflector shields that the kit didn't provide. Little stuff like this makes quite a difference.
Once the plastic strip joint had cured I sanded it down to shape.
