My B-17 G project
  • Peter Gillson
    • 2594
    My B-17 G project
    Hi guys
    having finished my WW1 dio, which I started in September (how time flys) I am about to start my next long-term project: a HK models 132 scale B-17G. It is a big kit!
    The kit has a lot of interior details so I have bought some crew figures from the Canadian company Ultracast to crew the aircraft. Since not a lot would be visible through the windoew, there is going to be a twist; I'm going to chop up the aircraft into a number of little vignettes.
    1- nose. Navigator and bombardier's area. The cut will be just infront of the cockpit. i'm toying with the idea of mounting it in a boxed dio so the viewer looks forward through the cut-section towards the nose But it may just be mounted on a brass rod.
    2 - cockpit, bomb-bay and navigators areas - simple cut-away areas in the side of the fuselage to reveal the interior details. The wings will be truncated.
    3 - waste gunner area; since gunners are firing out of both side a simple side cut-away may not work, so I am thinking of either a diagonal cut or mounting it so the viewer looks down the fusialge from frear to front, with the far end being the bulkhead and door to the radio operator's compartment.
    4 - tail. Not sure about this. It may be too small for a cut-away so I may mount it on the ground with a couple of pilots walking past.
    5 - landing gear. If by this stage i have the enthusiasm I am tempted to do a little vignette of the landing gar with a small amount of wing with some ground crew working on one of the engines.
    fortunately I found out that Meng Aircraft modelling mag has run a series following ghe build of hhis kit by David Parker, and what is nice is that you can download pdf's of specific articles for £1 each rather than having to buy the whole back issue.
    well, that's the plan, I am now just summoning up the courage to make a start.
    Peter
    well, that's the plan, lets see how it goes. nose are will be the first to work on.
  • Charlie Delta Foxtrot
    • Jan 2021
    • 383
    This is an epic kit! Cannot wait to see what you do with it, some amazing ideas you have for it!
      • 15670
      Hi Peter
      Now that's an idea for something different. Sounds as if you have given it a lot of thought already. An interesting project to follow. I hope it all works well.
      • adt70hk
        • Sep 2019
        • 10402
        Very interesting idea. Will look forward to this coming together.
        ATB.
        • Neil Merryweather
          • Dec 2018
          • 5184
          • London
          Fantastic, Peter! I can't wait!
          • Peter Gillson
            • 2594
            Hi guys
            it is a big kit - if built in one piece! David Parker, whose build is featured in 10 issues of Meng Air mag took 2 years. Fortunately my project means it will be a series of bite sized projects, each should take no more than a few weeks at most. I think that fitting the figures may prove to be the hardest part of each 'mini-project.
            Peter
            • flyjoe180
              • Jan 2012
              • 12390
              • Joe
              • Earth
              I hope you have a hangar for it Peter. Look forward to seeing it develop.
              • boatman
                • Nov 2018
                • 14451
                • christopher
                • NORFOLK UK
                HI Peter how big would it be if built whole wingspan an lenght ?
                but i'll be following as the guys say something different but i dont know if it was me if i could cut it up
                chris
                • Peter Gillson
                  • 2594
                  Hi Guys
                  Joe - fortuntely I'm chopping it up so storage will not be an issue, each section will be no bigger than a 1/35 tank.
                  Chris - the length would be about 2 feet, and the width about 40 inches - a bit of a monster. What is very clever is that the kit includes a bracket which fits in the bomb bay allowing the model to be mounted on a wall.
                  [ATTACH alt="image.jpg"]417617[/ATTACH]
                  Peter
                  • BarryW
                    • Jul 2011
                    • 6010
                    Sounds like a fascinating idea and its a way to build this huge kit without your having to buy a hanger for it. I will watch progress with interest. Good luck.
                    • BarryW
                      • Jul 2011
                      • 6010
                      By the way, I heard of someone getting around the size issue, with a full build, by building it into a coffee table with glass top and a mirror bottom. I imagine it would have had to somehow be fixed into place or it would scoot around every time the coffee table was moved.
                      • colin m
                        • 8741
                        • Colin
                        • Stafford, UK
                        What an epic project Peter. I do like the idea of making a series of smaller builds out of a huge build.
                        • Peter Gillson
                          • 2594
                          That's a really neat idea.
                          Peter
                          • Peter Gillson
                            • 2594
                            Epic is thd word - my last project - my WW1 all encompassing dio took me 6 months so this will take me at least until Christmas.
                            Petet
                            • Peter Gillson
                              • 2594
                              Hi
                              i hope you are all ok, enjoying Easter and looking forward to the relaxation of the UK lock-down. our lock-down ended a couple of weeks ago - over 30 days with no new Covid cases). It was quite strange on Thursday evening - Tina and I went to a birthday meal; 23 of us, first time in a long time that we had been part of a group and it did seem strange, but nice!
                              On Thursday these arrived In the post; 3 figures and loads of etched brass.
                              the detail on the inside of the kit is ok - think Tamiya tank internal details - its enough if you are peering through the small windows, but not enough for my project. I could have opted to scratch build everything, and nearly did, but in the end i sold some of my stash and bought the etched brass sets. These will really bring the inside to life.
                              the idea for the three figures is to have one/two/all of them walking under the wing past a wheel (which will be supporting part of the wing and at least one engine), making a nice little vignette based around the wheel.
                              Peter
ID:	1147973Click image for larger version
