Airfix’s Bristol Beaufort mk1
  • Charlie Delta Foxtrot
    • Jan 2021
    • 383
    New tooling for 2021, picked one up and it’s a great little kit. I’m adding a few bits and bobs in the cockpit, cables and some maps etc. But it’s been fun so far!Click image for larger version
ID:	1148510Click image for larger version
ID:	1148511Click image for larger version
ID:	1148512Click image for larger version
ID:	1148513Click image for larger version
ID:	1148514Click image for larger version
ID:	1148515Click image for larger version
    That’s looking really nice, particularly that navigators area.
      • Jan 2021
      • 383
      Thanks. I really want to make a little set of headphones to plug in to the radio and lay on top of the maps...Any ideas on what to use?
        Afraid not. Have you an example of them I could look at?
        If you’re making it up, it’s entirely up to you!
        • boatman
          • Nov 2018
          • 14453
          • christopher
          • NORFOLK UK
          HI Russell comin on very nice an can i ask you where you obtained the small maps as these would look good in my tigers bridge ?
          chris
          • boatman
            • Nov 2018
            • 14453
            • christopher
            • NORFOLK UK
            well in my opinion Russell for head phones as they will be tiny just use a bit of bent small wire in a n shape an stick on a couple of smale bits of round sprue on the ends for the ear phones an then paint black hows that ?
            chris
              • 18901
              Looking good Russel. What scale is this one?
              • Airborne01
                • Mar 2021
                • 3964
                • Steve
                • Essex
                I've used a strip of redundant PE (of appropriate size) and made the 'phones with sized pieces using styrene sheet and a Waldron punch and die set. Takes fine wire beautifully! The PE is easily blackened with burnishing fluid. PS The build is looking really good!
                • stillp
                  • 8091
                  • Pete
                  • Rugby
                  That's looking really good, but for a new tool those ejector pin marks are disappointing.
                    • Jan 2021
                    • 383
                    chris
                    I tried to print some maps but they just kept coming out A4...do enlisted daughter to help and she was able to get it much smaller but still not small enough so I took what she had done and simply cut out the bits I wanted; some land, some sea and that worked well enough.
                      • Jan 2021
                      • 383
                      I know, and I’m kicking myself I didn’t do anything about them now, live and learn. Of course, they’ll probably never be seen again once it’s closed up.
                        • Jan 2021
                        • 383
                        Great idea! I think I might go with the simple sprue idea though, for speed.
                          • Jan 2021
                          • 383
                          1/72
                            • Jan 2021
                            • 383
                            chris
                            That’s exactly what I will do! Thanks!
                            • stillp
                              • 8091
                              • Pete
                              • Rugby
                              I'm sure they won't be visible, and I wasn't criticising your build, it's just disappointing that Airfix couldn't avoid having so many on a new tool. Some are in really awkward places too. :disappointed2:
