Special Hobby 1/32 Fiat G.50-II 'Freccia'.
  • stona
    • Jul 2008
    • 9889
    #76
    The rain came, Hooray!
    The paint has dried enough for me to unmask the underside and white markings. The upper camouflage wraps around the leading edges of the wings and elsewhere goes much lower than most other schemes, so you really don't see any of the underside colour.
    That's it for today. Enamel paints mean that you can't rush, which for me at least is a good thing. A couple of coats of Klear tomorrow will be followed by the kit decals, which by all accounts are quite good.
    • outrunner
      • Apr 2019
      • 2420
      #77
      Terrific paint job, you must have the patience of a saint.
      Andy.
      • adt70hk
        • Sep 2019
        • 10428
        #78
        Looking very good Steve. Well done for persevering with it. That can't have been easy.
        ATB.
        • yak face
          • Jun 2009
          • 13852
          • Tony
          #79
          Fantastico ! What an amazing job . Its got to rank as one of the most difficult schemes to do , it looks superb steve . Looking forward to the macchi mc202 in smoke ring camo next
          • Airborne01
            • Mar 2021
            • 4001
            • Steve
            • Essex
            #80
            [ATTACH=CONFIG]n1150059[/ATTACH]
            Really good - do you spray camouflage jackets as well -that looks about the same scale!
            • stona
              • Jul 2008
              • 9889
              #81
              I'd say it was difficult in the sense that you do need a bit of patience and perseverance. The actual spraying isn't hard.
              I'm sure I did a smoke ring camouflage some years ago on the one and only other Italian job I have ever done. It's not on the shelves so it must have gone to the great attic in the sky.
              Really, doing the smoke ring camouflage would be a lot more straight forward than this bonkers scheme, which is probably why the Italians adopted it :thinking:
              Edit: I knew I wasn't imagining it!
              • Steve-the-Duck
                • Jul 2020
                • 1731
                • Chris
                • Medway Towns
                #82
                Damn, but the white band and cross are bright against the camo
                Noice!
                Ah, a C205. What kit and scale, can you remember?
                • Vaughan
                  • Apr 2011
                  • 3175
                  #83
                  Steve I think you've done a fine job with the camo you must of had the patience of a saint I'm impressed.
                  • stona
                    • Jul 2008
                    • 9889
                    #84
                    It's 1/32 so I don't think that it can be anything but the 21st Century Toys kit. I vaguely remember making some 'adjustments' to the tail, maybe the tailwheel area?
                    I usually keep photographs of builds from box to finish, but the only folder I have for this one is labelled 'Veltro' rather than the aircraft's proper designation (which didn't help finding it, typing variations of 'Macchi') and contains just half a dozen images of the finished model.
                    • Steve-the-Duck
                      • Jul 2020
                      • 1731
                      • Chris
                      • Medway Towns
                      #85
                      As I recall, and my one is at the bottom of stash 'B' (for 'bedroom', as opposed to 'A' for attic) the 21st Century 205 is quite a nice 'kit', albeit it screws together! I should dig it out and do a proper comparison to the Pacific Coast C.202 I've got
                      Please, if you've more finished pics, do post
                      • stona
                        • Jul 2008
                        • 9889
                        #86
                        Decals, such as they are, applied. There's only about a dozen of them.
                        The carrier film is very thin, which is good, but the decals do have a tendency to fold and one did break (though not irredeemably, it was the black '3' above).
                        The larger decals were applied in two or three parts where possible.
                        I would be very circumspect about applying a decal setting solution. I have applied an unused decal to a scrap model and will experiment with some Microsol before committing to this model.
                        Edit: It turns out that the decals are fine with Microsol. It's taken a couple of applications to achieve a decent result.
                        • Steve-the-Duck
                          • Jul 2020
                          • 1731
                          • Chris
                          • Medway Towns
                          #87
                          Oooh, soo pretty! Ahem...
                          Here's a factoid I have yet to have confirmed by a photo in any of my many Regia Aeronautica books; the fasces symbol on the fuselage side, and possibly also the wing roundels, were ACTUAL decals, stuck on not painted on.
                          This being the case, always use the transfers!
                          BTW, is that a squadriglia badge below the fin cross? That's a very rare placement because they'e invariably on the fuselage side, albeit without consistent positioning
                          Now I've got to dig my kit out and examine
                          ...Mine's a different issue..
                            • 18271
                            That is a true test of both patients and air brush control. Must have done your eyes in staring at the pattern while you painted.
                            • Steve-the-Duck
                              • Jul 2020
                              • 1731
                              • Chris
                              • Medway Towns
                              #89
                              There are, indeed, a few examples of badges on the fin, but I get the impression they're that rare beast of a personal mount.
                              Can't, so far, find any with that placement on anything but a G.50
                              Oh, and that bit about the real decals? The House of Savoy crest on the tail was also printed. Somewhere I've got a picture of one being applied, with the backing paper half removed
                              Now, THERE'S adio idea for you
                              • stona
                                • Jul 2008
                                • 9889
                                #90
                                I'm not surprised they applied the badges that way. It would be a hell of a stencil job with all the colours!
                                I'm just going with the profile in the kit. I'm guessing, since the aircraft is supposedly in Tirana, that it is based on this or a similar image, taken at the same place.
