Eduard 1/48 Bell Airacobra Mk.I - RAF brief service
Great progress dave , useful reference for when i get round to building mine ( the release with the naughty nose art - i think it will be the same plastic , but its only the weekend edition so no nose weight or PE for me :crying
At times you have to think that there are evil spirits lurking, trying to catch you out! I had the canopy sprue, kept safe in it's plastic bag - then, I stood up to answer the phone - >crunch< I'd somehow dropped the bag, and managed to put one of my size 11s on it. Main canopy shattered into 3 pieces -totally unrepairable!
I very nearly said a few blasphemies! :rolling:
Contacted Eduard, next morning, email, asking for my address - which I supplied & they told me one clear sprue will be posted to me - I feel a bit better now, but what are the odds on me dropping the thing unnoticed, the phone ringing & me putting my foot on it. (phone call was an Amazon fake call, as well )
Luckily, I can go most of the way to making the Airacobra before I need the canopy, but really!
The airframe mostly complete - the fit is a bit patchy, a lot of trimming & sanding & a lot of dry fitting.
A touch of filler here & there, but not too bad. There are several bits of PE added - two mesh filters at the rear of the wing root inlets.............totally invisible, I should have used the plastic parts. There are PE parts for the flaps on the 3 radiator duct outlets ( just above the wheel wells ), and plastic parts - I cannot see any benefit to using the PE, it just looks like a fret filler!
I'll give the joints a primer test, before masking up & spraying overall primer. I can work around the lack of a canopy for the moment.................
I blocked all the openings, either with wet tissue paper, or masking fluid. After an overall covering of grey primer, I painted the 'Sky' band around the rear fuselage, then masked it up, after drying. I then sprayed the underside with Medium Sea Grey. After more drying, I masked up & sprayed the upper surfaces Ocean Grey. After an hour or so, I brush painted the Dark Green Camo pattern.
A little bit of touch up needed here & there but not bad. I'll give it an overall gloss spray, before decalling, I'll be able to work around the missing canopy & doors almost until completion
After an overall spray of gloss varnish - the decals.................................
I'm using MiG decal solution, and these Eduard decals seem to be reacting a lot! They're wrinkling up far more than I've seen before - I haven't even put the second part of the solution on yet! I hope I don't have to go hunting in my extensive spare decal files ( OK, the shoe box ) for replacements.
