Trumpeter 1/32 P40 F Warhawk
  • BarryW
    • Jul 2011
    • 6010
    #16
    I have been working on the fuselage seams and while waiting for Mr Dissolved Putty to dry completed a couple of sub assemblies.
    Fit of all parts rather good. No real
    Issues at all.
    • BarryW
      • Jul 2011
      • 6010
      #17
      Wing attached, great fit and also I have been attaching ‘bits and bobs’.
      • adt70hk
        • Sep 2019
        • 10406
        #18
        Coming on nicely Barry.
        • BarryW
          • Jul 2011
          • 6010
          #19
          Preparing to paint. Fixing the canopy into position and masking.
          • BarryW
            • Jul 2011
            • 6010
            #20
            I have applied a black primer and it looks like there are just a couple of small seam areas that need attention.
            I used my spreader cap for the second time so I have now worked out how to get the best out of it. It really does turn a fine airbrush into a spray gun that’s ideal for this purpose. I covered the model quickly with a thin smooth coat. If there is one available for you airbrush I recommend that you get one.
            • Steven000
              • Aug 2018
              • 2827
              • Steven
              • Belgium
              #21
              Nice progress Barry :thumb2:
              • BarryW
                • Jul 2011
                • 6010
                #22
                Some progress shots.
ID:	1150582Click image for larger version
ID:	1150583Click image for larger version
                • BarryW
                  • Jul 2011
                  • 6010
                  #23
                  I have decided to freehand the camo with the darker colour, the US version of Dark Earth first. My aim was to give a reasonable accurate outline of the pattern and ighten it up with the Mid Stone.
                  I plan to do the Mid Stone with my H&S with the .2 needle set.
                  • BarryW
                    • Jul 2011
                    • 6010
                    #24
                    Here is the Mid-Stone applied. I am not completely sure about the colour demarcation. I wanted a soft edge but I am not sure if it’s too soft.
                      In the photo, it looks a little blurry, almost as if you’ve sprayed a third colour along the edges. I think I’d try to touch up the edges to make them a bit sharper if it were my model.
                      • BarryW
                        • Jul 2011
                        • 6010
                        #26
                        I think that you are right Jakko.
                        • BarryW
                          • Jul 2011
                          • 6010
                          #27
                          I have worked on the camo and sprayedthe exhausts.
                            That looks much better, if you ask me. The edges are sharper, as they should be for RAF camouflage, and the odd blurring effect/grey line between the colours is gone.
                            • BarryW
                              • Jul 2011
                              • 6010
                              #29
                              Another shot of the model.
                              I decided to airbrush on a couple of coats of a water based acrylic gloss varnish using the spreader cap. I want a barrier between the lacquer paint and the lacquer varnish I will spray later.
                              When I spray water based products like this I am always reminded just how brilliant the lacquers are!
                              • BarryW
                                • Jul 2011
                                • 6010
                                #30
                                I have applied the Kits World decals and, I have to say, they are the among the best decals I have used. Not just the great artwork but they have laid down really easily no splintering at all and thin enough to conform. I have applied Microsol to them and they are drying.
