Heres another of the excellent zvezda i-16s im on with . Its going to be in Finnish airforce markings , this aircraft was captured and used by the Finns against the Russians . The decals are coming from the excellent print scale sheet and its going to need a bit of fettling in the shape of some scratchbuilt skis and a rebuilt propeller. Heres the airframe with a bit of paint on it .
Polikarpov i-16 ,captured Finnish airforce conversion 1/144 zvezda kit
Bit more on this one - the skis have had a 0.6 mm hole drilled in them for the main undercarriage strut . The 3 struts will be made with fibre optic strand from one of those cheapo UFO lamps - see here https://www.scale-models.co.uk/threa...e-3#post-49009
Ive also been sorting the propeller . This aircraft had the bare propeller hub so the kit one with spinner had to be butchered. I cut off the blades and set about making a centre section and spindle , the micro pcb drill bits coming in very useful again. The round section of plastic rod had a tiny 0.7 mm hole drilled through it for the spindle which was micro brass tube, then the prop blades were superguled on . Ive also fitted and painted the windscreen . Next up is a varnish and decals .Comment
