Revell 1/72 DC-4 Blair plus lighting
  • peterairfix
    • Jul 2012
    • 11075
    #16
    The wiring will fit I just have to get some more mini leds and fibre optic and relocate the battery box to outside the aircraft. Click image for larger version
    • boatman
      • Nov 2018
      • 14466
      • christopher
      • NORFOLK UK
      #17
      GREAT Peter you can do it but you may need some soldered exstenion wires but that easy enough to do but i think it will bring the plane to life an look brillant with the lights down low like i do on my big USS ENTERPRISE
      Chrisb mtb
      • tr1ckey66
        • Mar 2009
        • 3592
        #18
        Good plan Peter. Cockpit looks the biz.
        It's good that you've found room for the lighting wiring. Will you run motors for the props?
        Paul
        • boatman
          • Nov 2018
          • 14466
          • christopher
          • NORFOLK UK
          #19
          Paul
          YES Peter that would look great as i did that on a big monogram B29 enola-gay droppin the A -BOMB an it looked super on its stand very realistic
          chrisbmtb
          • peterairfix
            • Jul 2012
            • 11075
            #20
            I have decided to have another go and finish it and I have decided to ditch lighting as it was giving me a headache
            So I am going to be doing the Iceland Airways scheme and have put some paint on. Click image for larger version
            • peterairfix
              • Jul 2012
              • 11075
              #21
              I just remembered from a previous build of this one that it was tail heavy so i am going to try this Click image for larger version
              • peterairfix
                • Jul 2012
                • 11075
                #22
                I have finally got the wings fitted and trussed up with a mountain of masking tape. Click image for larger version
                • peterairfix
                  • Jul 2012
                  • 11075
                  #23
                  I have now fitted the tail and undercarriage but this is so tail heavy I have filled the entire front landing gear bay with weight and its still tail heavy Click image for larger version
ID:	1194032Click image for larger version
                  • adt70hk
                    • Sep 2019
                    • 10409
                    #24
                    That's lot of weight Pete. Looking good though!!
                    • peterairfix
                      • Jul 2012
                      • 11075
                      #25
                      Weight problems sorted. Click image for larger version
                      • Mickc1440
                        • 4775
                        #26
                        Looking good Pete, certainly taken some weight to tame it
                        • peterairfix
                          • Jul 2012
                          • 11075
                          #27
                          Almost finished I was just painting the leading wing edges black because I had forgotten to I tested the decals had settled with a bit of tape yep it was OK but when I had finished I pulled the tape off carefully and bugger you can guessed what happened.
                          OH Click image for larger version
                          • JR
                            • May 2015
                            • 18273
                            #28
                            Damn that's a bummer Peter.
                            Looking fwd to the lighting going in .
