My next build....
The aftermarket.
The insignia will be painted while I will use the Kits World decals for the rest. I see a lot of builds of Squirt II so I will be building the other one with the white tail, Miss Mutt. Great nose art from Kits World as usual. You might be able to see a seatbelt set from Fine Molds in the pic. I have several sets of these to use up but, in future, my first choice for these will be the 3D decal sets that are currently gaining popularity.
The surface detail seems a little heavy but not as bad as some. Under paint and varnish it should look perfectly OK.
There are no less than four props! I will need to be careful to find the right one.
Plenty of underwing stores too. My spares box is going to grow a lot!
The are some vinyl, etch and film components too.
All sprues labelled and bench set up ready....
The aftermarket.
