Good idea steve , the galeria can go a bit funny after a while . I got a big ( 250ml) bottle thinking i was being economical but it went funny, with lots of tiny white flecks in it that didnt go away with stirring . These flecks either blocked up the airbrush or if they went through left white spots on the model . Needless to say I dont use it anymore . I might try and get a bit of muslin and see if i can strain them out .
ICM 1/32 Fiat CR.42 Falco
Good idea steve , the galeria can go a bit funny after a while . I got a big ( 250ml) bottle thinking i was being economical but it went funny, with lots of tiny white flecks in it that didnt go away with stirring . These flecks either blocked up the airbrush or if they went through left white spots on the model . Needless to say I dont use it anymore . I might try and get a bit of muslin and see if i can strain them out .Comment
The Winsor and Newton one really is matt and I've found it sprays and cleans up very nicely. To be fair to W&N, that bottle has been stored in a cupboard subject to a wide range of temperatures for a long time, I can't remember when I last used it, but years. It is not unreasonable that it has deteriorated.Comment
More progress.
I've got the varnish done with the desired flat result. I've also attached the wing. There are a few more struts to go and a few bits of rigging and then it will just be a matter of adding the final touches (a bit of weathering, though apparently most of the aircraft delivered to Belgium were brand spanking new, propeller, guns, lights, etc.)
I'll probably leave this thread here, except to add a link to a completed thread when the model is indeed complete.Comment
Looking good Steve. Surprising how yellow the camouflage is isn’t it. Great for the dry areas of Southern Italy and the Med, but not so effective for Northern Europe!Comment
Not bad at all. The fit is very good. I started by attaching the struts that attach the wing to the fuselage to the wing, in two stages, keeping the lower end in position on the fuselage with tape. Once that was all set I realised there was enough play in the outboard struts to fit them with the top wing attached to the fuselage so I glued it on (there are six good attachments to the fuselage) and continued with the struts. I remembered to do the rigging wires before the last, most outboard, set of struts! It would be a right pain to do at the end.
I reckon if I was going to start building loads of biplanes I might bodge together some kind of jig to hold the wings, I did tend to run out of hands from time to time.Comment
The British certainly agreed. They thought that it was basically a tropical camouflage scheme when they examined the aircraft deposited across East Anglia by the Italians.Comment
ISTR the Italian Air Force later reversed the colours, when their aircraft were operating over the Italian mainland, so that it went from yellow with dark areas to dark with yellow areas, and was much more effective there. Seems odd nobody thought of this before despatching aircraft to operate over the UK …Comment
Might be that this camouflage is the factory finish specification and these were new issued aircraft?Comment
