Tamiya 1:32 F-14
  • Ancientmariner
    • Feb 2018
    • 859
    Tamiya 1:32 F-14
    So shed is pretty much complete so now making the most of it.
    Had this a while and have actually started it but thought I'd do a new thread.
    The kit is very old, how old I don't know but looking at it I assume pre 2000. Decals are a bit on the yellowed side so will probably replace these and maybe go for a different scheme to the box but apart from that the kit seems all good.
    Aires cockpit set will be used as well. This seems a really excellent addition. I have never used one of these but am very impressed from the level of detail.
    Unboxing photos below.
    Do you mean the first release of this kit, or when you bought it? I can’t help with the latter, but the kit originally came out in 1980.
    • colin m
      • 8740
      • Colin
      • Stafford, UK
      A great looking aircraft James, and you've got lots of plastic to play with, nice.
      • Ancientmariner
        • Feb 2018
        • 859
        So cockpit rear (Goose's seat) almost done, though the PE is hard going, just so fiddly as there are about 16 parts to the belts for each seat, at least with this kit it should be visible though so worth the extra effort.
        Anyway once this is done I am looking forward to being able to progress at a higher rate of knots!
ID:	1155354Click image for larger version
ID:	1155355Click image for larger version
        • yak face
          • Jun 2009
          • 13829
          • Tony
          Cockpit looking excellent james , loving the radar screen and mfd
            • 22770
            A great start.
            • adt70hk
              • Sep 2019
              • 10402
              A fantastic start.
              Very well done indeed.
              • colin m
                • 8740
                • Colin
                • Stafford, UK
                This is looking quite splendid.
                • Ancientmariner
                  • Feb 2018
                  • 859
                  So after a long break and a lot of trains being done did a bit more on the cockpit yesterday.
                  Still have to glue in pilot's seat, stripe ejection seat handles in front and do pilot seat straps but pretty much done apart from that.
                  Certainly think this Aires set makes a nice.cockpiy and a bit of detail which will be seen.
                  Dry fit is doesn't seem to want to fit very well in the nose section of the fuselage.
ID:	1160665Click image for larger version
ID:	1160666Click image for larger version
ID:	1160667Click image for larger version
                  • adt70hk
                    • Sep 2019
                    • 10402
                    Coming on very nicely!!
                    • rtfoe
                      • 9073
                      Hi James, I just dropped in and did some catching up. The office looks nice with the Aires set. To know if the kit is old and if I'm not mistaken the front half of the kit is raised panel lines and the back half engraved.
                      • Mark1
                        • Apr 2021
                        • 4156
                        Cockpit looks superb.
                        • Ancientmariner
                          • Feb 2018
                          • 859
                          To thanks for all the compliments!
                          Front panels have come out better as I painted white behind before gluing on films with dials on them where as I didn't in the back.
                          The front has recessed panel lines and back has proud ones, I'm not sure what that equates to age wise?
                          • rtfoe
                            • 9073
                            Oops...I got that in reverse. Yup...that's the old kit alright. Now I remember some people saying that Tamiya either ran out of patience or there were two separate design teams working on the moldings that had this half and half thingy... pretty weird. I've not seen the newer moldings but haven't heard any complaints about the panel lines.
                              • 18892
                              Looking good in the cockpit James. Nice job.
