Looking good, shame about the fit issue,at least its a problem that can be overcome :thumb2:
Tamiya 1:32 F-14
So ended up spending some hours this evening sorting the forward wheel bay and adding some copper and lead wiring to add a bit more detail and some different finishes.
Have to varnish tomorrow before pin wash and then Matt varnish and glue together.Comment
My F14 has Aires tub and also the 1/32 lightning I have has Aires tub too.
I have never done the wheel bays actually with detail kits. Just saw this thing with the wire on YouTube.
Look forward to seeing the F16 build!Comment
So being so long since I did anything to this post I thought I'd make some progress to post about.
The issue with the canopy killed any drive I had for this project however I think it is salvageable so am continuing.
Bits of the body are together, the fit is dreadful. Ever joint will need filling and sanding extensively but this will be good as it's something I'm very bad at and need to practice. Any tips are welcomed!
Done the intakes white (over black undercoat to give it some depth and texture) and will put top half on today.
Managed to break one ejector seat handle which I will need to remake from scratch up never mind.
