Tamiya 1:32 F-14
  • Ancientmariner
    • Feb 2018
    • 859
    #121
    Originally posted by boatman
    WELL James due to the time of the yr it may take longer
    chrisb
    Yeah there was no option for SD as I'd have paid the extra £3 just to get it quicker.
    • Ancientmariner
      • Feb 2018
      • 859
      #122
      So after a long wait the canopy arrived. Annoyingly while removing the flashing I dropped a file on it so need to buff out the damage and clear coat it away. Fit isn't as good as I'd like so will likely be open when done.
      Mr Colour clear GS super smooth gloss applied all over and done decals on one side.
      I have only applied the extra decals for this side, none of the standard ones yet (not step markings etc).
ID:	1214428Click image for larger version
ID:	1214429Click image for larger version
      • boatman
        • Nov 2018
        • 14479
        • christopher
        • NORFOLK UK
        #123
        VERY Nice James very unusual colour but i like it should look a great model when maskin is removed brilliant modelin
        chrisb
        • Ancientmariner
          • Feb 2018
          • 859
          #124
          So a grey dull day, so best place to spend it was the shed.
          Extra decal sheet all applied and I have used the Tamiya ones that were common to all makes of F14A just to add detail and features.
          A longer soak and washing up liquid removed them without any cracking like I'd had before.
ID:	1214604Click image for larger version
ID:	1214606Click image for larger version
ID:	1214607Click image for larger version
          Also decided to start making a base.
          50 x 50 sheet of MDF, routed the edges and then covered top in filler and waiting for it to dry.
          • Ancientmariner
            • Feb 2018
            • 859
            #125
            So base research.
            Google Earth amazes me. Literally in 5 mins went to NAS Fallon, looked at the apron and found the bit I am going to use.
            50cm x 50cm base works out 16m x 16m at 1/32 scale.
ID:	1214640Click image for larger version
            • Ancientmariner
              • Feb 2018
              • 859
              #126
              Decals completed, clear coat applied and drying now.
              Front part of canopy done but not fixed in place as yet.
ID:	1214762Click image for larger version
              Also started marking the base today. Have decided to put in lights for taxi way so drilled pilot holes for these.
              • boatman
                • Nov 2018
                • 14479
                • christopher
                • NORFOLK UK
                #127
                LIGHTS on taxi way should look good James
                chrisb
                • Ancientmariner
                  • Feb 2018
                  • 859
                  #128
                  Base sanded, holes drilled for tie down pints which is what I think is in the centre of each slab (educated guess as it's a naval Air station). I have ordered some 3d printed ones off eBay which I have drilled pilot holes for, main holes to be drilled when they arrive.
                  Sprayed with under coat, have to rout the back now with channels for wires and recess for the battery box and switch.
                  • boatman
                    • Nov 2018
                    • 14479
                    • christopher
                    • NORFOLK UK
                    #129
                    James SHE looks really good an im pleased that you dint bin it as i think all big models deserve a chance at gettin fininshed brilliant modelin sir very well done
                    chrisb
                    • Ancientmariner
                      • Feb 2018
                      • 859
                      #130
                      So no plane progress but progressed the base.
                      Undercoated and lights for taxiway fitted. Cheap £1.99 LEDs of Amazon. Just used router to make space for battery pack and wires.
                      • boatman
                        • Nov 2018
                        • 14479
                        • christopher
                        • NORFOLK UK
                        #131
                        well DONE James very nice work on them leds
                        chrisb
                        • Ancientmariner
                          • Feb 2018
                          • 859
                          #132
                          Filled in the tie down pilot holes as they are never going to be here before Xmas. Pre shade done for tomorrow's top coating.
                          • boatman
                            • Nov 2018
                            • 14479
                            • christopher
                            • NORFOLK UK
                            #133
                            HELLO James just been lookin through your build again an is that copper foil tape on the bottom of your board as i found this very good on my nimitz aircraft carrier on the nr 9ft long flight deck an all in i used 18ft worth to power the flightdeck lights very good that foil is
                            chrisb
                            • Ancientmariner
                              • Feb 2018
                              • 859
                              #134
                              Hi Chris,
                              No I think it is just the way the light has caught it.
                              That's just a 1.99 set of pre wired green LEDs cut down to only 6 lights. I did but a big mixed pack of LEDs etc but decided to use these ones to start just to make it easier and save time.
                              Base board is basically painted apart from sides now. Still needs to be weathered and have dirt applied. I have removed the lights and these are to be set in clear resin in their respective channels.
                              • Steven000
                                • Aug 2018
                                • 2828
                                • Steven
                                • Belgium
                                #135
                                Lovely project James, looking forward to the next steps :thumb2: Cheers
