SMER (Heller) 1/72 Dewoitine d501
  • Mark1
    • Apr 2021
    • 4156
    #16
    Thanks for teaching me how to do a wooden prop, :smiling: :thumb2:
      • 22771
      #17
      Looking good
        • 18934
        Good work Tony. Very useful colour is Tamiya clear orange. Gives a great varnished wood effect, enhanced by it drying semi gloss rather than Matt. Consistency takes some getting used to though, and it’s not one for your best brushes! Vallejo clear orange just doesn’t give the same effect.
        • yak face
          • Jun 2009
          • 13855
          • Tony
          #19
          Yes its a tricky one to brush isnt it tim , gives great results though .
            • 18934
            It does doesn’t it. I’m not even sure what the formulation is though Tony. It’s not like normal Tamiya, it even smells different.
            • Vaughan
              • Apr 2011
              • 3175
              #21
              Tony that's one very realistic wooden prop.
              • colin m
                • 8771
                • Colin
                • Stafford, UK
                #22
                Nice wood. I've used the same trick with wheels like them. A Lysander I think.
                • yak face
                  • Jun 2009
                  • 13855
                  • Tony
                  #23
                  The engine cover and nose have now been fitted . Before I glued the wing top pieces i had to open up a marked hole for the undercarriage leg. Problem is there are 2 holes on each wing , marked A and B , the smer instructions not giving any clue which one to use . Luckily Scalemates website had the original heller instructions to download which showed that A was the one to use. After this the wing tops were fitted. The only joint that needed more than a quick sanding was the rear of the wing bottom to the fuselage which has been filled . The prop has had the endplate painted and the cannon drilled and painted gunmetal . The endplate isnt perfectly round but you can only work with what you get . Next up tomorrow is fitting the radiator, tailplanes and undercarriage. Click image for larger version
ID:	1155154Click image for larger version
ID:	1155155Click image for larger version
ID:	1155156Click image for larger version
ID:	1155157Click image for larger version
ID:	1155158Click image for larger version
ID:	1155159Click image for larger version
                  • yak face
                    • Jun 2009
                    • 13855
                    • Tony
                    #24
                    Airframe all together now , just a few tiny bits to add later .I’m not sure whether to fit the windscreen now or wait till after painting . Next step is to prime the tail with white and once this has had a coat of red it will be masked up and the whole lot will get some nice gloss black primerClick image for larger version
ID:	1155196Click image for larger version
                    • colin m
                      • 8771
                      • Colin
                      • Stafford, UK
                      #25
                      I like the look of this strange little thing.
                        • 18934
                        Interesting bird. It would look good displayed with a model of Indiana Jones!
                        • scottie3158
                          • 14225
                          • Holbeach
                          #27
                          Tony,
                          looking good, very different to the normal offerings.
                          • Allen Dewire
                            • 4741
                            • Allen
                            • Bamberg
                            #28
                            Oh and don't forget Tony........Dora Wings are releasing a D.501 in 1/32 scale, (kit DW32002) if your eyes get too buggy and the nerves are shot from building this one. She is looking mighty nice so far Sir!!!
                            Allen
                            • yak face
                              • Jun 2009
                              • 13855
                              • Tony
                              #29
                              Allen
                              It would look great in 1/32 allen , its quite a large wingspan , four feet bigger than a spitfire . I bet its not a cheap kit though .
                              heres the airframe in gloss black primer and after the vallejo metal color Click image for larger version
ID:	1155564Click image for larger version
                              • colin m
                                • 8771
                                • Colin
                                • Stafford, UK
                                #30
                                The nice bit (for me) paint. Looks nice.
