SMER (Heller) 1/72 Dewoitine d501
    • 15746
    Hi Tony
    That's a fine looking paint job. Those Vallejo metallic paints are rather good.
      • 18934
      Looks great.
      • flyjoe180
        • Jan 2012
        • 12440
        • Joe
        • Earth
        #33
        Superb work Tony, and I've made a note of your fantastic wooden propeller technique. :thumb2:
        • yak face
          • Jun 2009
          • 13855
          • Tony
          #34
          The model has now had a coat of Alclad aqua gloss , decals , and another sealing coat of aqua gloss.The decals went on fine , the tail stripe decals being the trickiest as you always have to trim and touch them up . Just a few last bits to put on tomorrow , windscreen , guns , aerials, headrest , wheels , then the exhausts to paint and a pin wash for the control surfaces. Its not getting any weathering as the few period pics show very clean machines , not even a trace of exhaust staining .Click image for larger version
ID:	1155735Click image for larger version
            • 22771
            #35
            Great work Tony
            • outrunner
              • Apr 2019
              • 2420
              #36
              Great looking finish.
              Andy.
              • Mark1
                • Apr 2021
                • 4156
                #37
                Nice job,might have to try some of those alclad paints.
                • yak face
                  • Jun 2009
                  • 13855
                  • Tony
                  #38
                  Its only the clear coat thats Alclad mark ,and thats one of their water based acrylic finishes. The silver is Vallejo Metal Color , another water based acrylic . I tried the Alclad metallic laquer paints once and couldnt get on with them , they didnt cover well enough for my liking plus they really stink ! Ive found these Vallejo metal color paints to be very suited to my style , theyre the most hard wearing , forgiving metallic acrylics ive come across so far . Heres a link to Johns shop https://www.scalemodelshop.co.uk/pro...s/metal-color/
                  • adt70hk
                    • Sep 2019
                    • 10433
                    #39
                    Tony.
                    That's coming on very nicely indeed. I remembered someone mentioning a certain Vallejo range of metallic paints were very good but couldn't remember which ones, so thanks for the tip.
                    I see these are specifically designed for airbrushing. Do they need much thinning on top? Also have you tried then with a brush on smaller areas?
                    Thanks.
                    • yak face
                      • Jun 2009
                      • 13855
                      • Tony
                      #40
                      Thanks.
                      They just spray straight from the bottle andrew , just a quick shake ( theres a ball bearing in the bottle too) and off you go . I usually apply them over a gloss black primer . Theyre very hardwearing and take a lot more handling and masking than the model air metallics , As for sealing the finish either Klear or alclad aqua gloss, i tried their own metal color varnish but it was a bit thick and I did t fancy thinning it for fear of it separating on the surface .I have tried brushing , its fine on smaller parts , if a little thin , but on a larger surface you would struggle to get rid of brush marks hope this helps cheers tony
                      • yak face
                        • Jun 2009
                        • 13855
                        • Tony
                        #41
                        Got all the final little bits done so im calling this done. Its been a quick , trouble free build and its a lovely looking thing , almost art deco in appearance . The wide track , lovely spatted wheels and the long elegant wings make it look more like a circuit racer than a warplane . Heres some pics to round off the build , i’ll be putting some on a completed thread once ive took them off the camera and put them on the laptop thanks to all who've been watching , Vive la France !!
                        regardez Antoine Click image for larger version
ID:	1155753Click image for larger version
ID:	1155754Click image for larger version
ID:	1155755Click image for larger version
ID:	1155756Click image for larger version
ID:	1155757Click image for larger version
                        • Vaughan
                          • Apr 2011
                          • 3175
                          #42
                          Tony what a result, great paint job and a very realistic wooden prop.
                            That looks very good. The plane isn’t my cup of tea, but the model is very well done.
                              • 18934
                              C’est superbe Antoine!
                              • Neil Merryweather
                                • Dec 2018
                                • 5201
                                • London
                                #45
                                Luvley!
