OEZ 1/48 Sukhoi su7
Tony, your instrument panel finish is way better than mine. I totally forgot about the ejection seat height issue. Even the original seat needed thinning at the base. The problem is compounded by the thick plastic of the clear canopy. So I had mine open. Glad you fixed the issue.
Just a little warning...the wing roots need dry fitting to determine the angle of the enhydral. Also be ready for fillers. I decided to glue the top and fill the gap on the underside.
The vertical tail stabiliser also needs a lot of filler at the joint to the fuselage unless you shape a groove to fit the contour of the fuselage.
RichardComment
RichardComment
Got a bit more done on this last week but been too busy to post anything so heres an update. The problem of the nose weight has been ( hopefully) solved by adding plenty of weight in the form of 3 circular discs of lead cut from an old piece of roofing lead sheet ,sandwiched between the cockpit and the nose intake assembly. The fuselage has now been glued together and the tail fitted . The tail took quite a bit of fettling to get a decent join , the top of the fuselage was round and the underneath of the tail flat , plus I had to widen the front of the tail with a sliver of plastic card so it matched the spine on the fuselage. Another area that needed careful assembly was the nose intake . The location of the central nose cone was very vague , but its essential its bang central so a lot of dry fitting and adjusting went on before final gluing.
A test fit of the elevators shows a lot of work needed here too , the huge gap needs sorting .Comment
