Airfix 1/48 Supermarine Walrus Mk1
  • peterairfix
    • Jul 2012
    • 11082
    This one's been calling me for some time so time to make a start.
    So far it's been concentrating on the cockpit no problems encountered. Click image for larger version
ID:	1156804Click image for larger version
ID:	1156805Click image for larger version
ID:	1156806Click image for larger version
    • 18944
    Nice start Peter . They’ve got one at the Yeovilton museum, not far from you….
      • 22788
      A very nice start Peter as Tim says.
      • yak face
        • Jun 2009
        • 13870
        • Tony
        Lovely cockpit peter , looks a nice kit . Cheers tony
        • peterairfix
          • Jul 2012
          • 11082
          More work done on the interior not much in the way of work for the sides and top and I have got the first coat of aluminium paint on ready to put everything together. Click image for larger version
ID:	1156854Click image for larger version
ID:	1156855Click image for larger version
          • scottie3158
            • 14243
            • Holbeach
            Peter,
            Nice start mate.
            • adt70hk
              • Sep 2019
              • 10438
              Coming on nicely Peter. Can't be small at that scale.
              Keep up the good work.
                Coming on well , there's certainly some ribbing there .
                • peterairfix
                  • Jul 2012
                  • 11082
                  I have the fuselage sewn up but it needs a bit of tape to keep it together and I have the undercarriage and wheels attached and the start of the engine. Click image for larger version
ID:	1156890Click image for larger version
ID:	1156891Click image for larger version
ID:	1156892Click image for larger version
ID:	1156893Click image for larger version
ID:	1156894Click image for larger version
ID:	1156895Click image for larger version
ID:	1156896Click image for larger version
                  • rtfoe
                    • 9114
                    Oh man...all that interior covered up. I felt the same fitting the fuselage together on my 1/72 scale Matchbox kit after scratching the whole interior. :confounded:
                    Peter, I wonder if Airfix has the engine facing off one or two degrees forward like the real aircraft to counter the torque from the propeller? I thought Matchbox had screwed the molding until my reference showed it to be correct.
                    • peterairfix
                      • Jul 2012
                      • 11082
                      I have just fitted the engine pod and look from top down it is off centre by a few degrees.
                      • peterairfix
                        • Jul 2012
                        • 11082
                        I am afraid that my threads aren't the best because if the kit doesn't give me any problems I tend to wizz through the construction.
                        But here is the latest it's almost finished I am just awaiting a masking set so I can do the windows. Click image for larger version
ID:	1156915Click image for larger version
ID:	1156916Click image for larger version
ID:	1156917Click image for larger version
ID:	1156918Click image for larger version
                        • scottie3158
                          • 14243
                          • Holbeach
                          No worries Peter, looking really goid so far.
                          • peterairfix
                            • Jul 2012
                            • 11082
                            I have masked the front canopy and started on the rigging. Click image for larger version
ID:	1157100Click image for larger version
ID:	1157101Click image for larger version
