Zoukei Mura Hs129B-2/ RIII, 1/32 scale.
  • adt70hk
    • Sep 2019
    • 10415
    #46
    Coming on very nicely Barry.
    ATB.
    • BarryW
      • Jul 2011
      • 6028
      #47
      The just arrived, 1 Man Army paint masks. Fortunately the masks I bought previously are generic and will get use on other projects. I could not resist getting these from this new company as they include fine, small detail, stencilling and not just the main markings. Good bye completely to decals….
      [ATTACH]436173[/ATTACH]
      They provide very detailed instructions
      [ATTACH]436174[/ATTACH]
      [ATTACH]436175[/ATTACH]
      [ATTACH]436176[/ATTACH]
      [ATTACH]436177[/ATTACH]
      The individual stencils are numbered on the sheet.
      [ATTACH]436178[/ATTACH]
      I will demonstrate their use in the thread. The Zoukei Mura decals are really quite decent as was shown with the i.p. but no decal can compete with painted markings….
      • BarryW
        • Jul 2011
        • 6028
        #48
        I have sprayed the rear of the cockpit RLM02 as this area will be visible. I still need to apply a wash along with dry brushing some metal powder to show wear and chipping.
        [ATTACH]436180[/ATTACH]
        Below the tail wheel after dry brushing first the inner wheel with metal powder and the tyre with Earth pigment to give it a browny dusty look.
        I have also got a floor section ready.
        [ATTACH]436179[/ATTACH]
        When I have tied up a few detail here it will be onto the wings.
          • 15722
          Hi Barry
          Great, neat, well thought out progress. Hope the shelf cost is reasonable. I'll look forward to seeing how the masks work out. Masks certainly give a better finish than decals most of the time.
          • adt70hk
            • Sep 2019
            • 10415
            #50
            Coming on very nicely Barry!
            • BarryW
              • Jul 2011
              • 6028
              #51
              The engineering of this kit is a thing of beauty and the instructions could not be better.
              I did a fair bit of light sanding of the wing spars before fitting, not because of poor fit as such but I am aware that tolerances are tight. It is important not to try to force fit anything, if a part sticks just sand it lightly. The spars slid into position beautifully.
              [ATTACH]436253[/ATTACH]
              Then on to fit the fuel tanks and other wing internals
              [ATTACH]436251[/ATTACH]
              With this kit it really is important to look at the instructions. How many of us would just cement the fuel tank halves together? If you did there would be an issue. The bottom need to be slid into the wing position first and cemented in place, for the top to then be dropped in on top.
              [ATTACH]436250[/ATTACH]
              [ATTACH]436252[/ATTACH]
              [ATTACH]436254[/ATTACH]
              I found how useful it is to use a combination of extra thin, quick drying cement and a slower drying one. Then I notice, after completing the wing, that ZM themselves point this out in the next section of the build….
              [ATTACH]436255[/ATTACH]
              These meticulous instructions are a joy.
              • BarryW
                • Jul 2011
                • 6028
                #52
                Just to say that I will not have any open panels so that detail won’t be seen hence my not painting it. You could leave a lot of this out, of course, but including it gives the model a satisfying heft and some added rigidity.
                What I really like about ZM is how the engineering really gives you an appreciation of how the actual aircraft was designed. Also thanks to the instructions you know exactly what it is you are working on, it is not just a matter of cementing C1 to C4!!!
                • rtfoe
                  • 9088
                  #53
                  [ATTACH=CONFIG]n1161571[/ATTACH]
                  [ATTACH=CONFIG]n1161569[/ATTACH]
                  [ATTACH=CONFIG]n1161568[/ATTACH]
                  [ATTACH=CONFIG]n1161570[/ATTACH]
                  [ATTACH=CONFIG]n1161572[/ATTACH]
                  [ATTACH=CONFIG]n1161573[/ATTACH]
                  Instructions look fantastic but engineering for this kit perhaps a bit disappointing... five visible ejector pin marks in the cockpit is really surprising. It is though, a very full assembly that warrants open panels to show off the interior. They should make another option without too much interior with less cost to build an all closed version.
                  Build is looking good so far Barry, have you aligned the front nose yet as the picture shows the gun ports on the side cheek a little askew.
                  • BarryW
                    • Jul 2011
                    • 6028
                    #54
                    Personally I find nothing disappointing at all on the engineering. There are few visible ejection pin marks, those that are, are shallow and easy to clean up. I don’t agree about an option without the interior, simply because the cost is not in the plastic, so producing another version with missing parts would not save much and so would be pointless. I speak as someone who does not do open panels.
                    Thanks for pointing out the nose gun port but it is not an issue as I left it with some ‘play’ to ease fitting the ‘skin’ and it had clicked out of position just before I had taken the photo. It is now clicked back in, at least for now!
                    • adt70hk
                      • Sep 2019
                      • 10415
                      #55
                      Coming on very nicely indeed. That really is looking very, very good indeed
                      Those instructions do look the business too.... Almost a work of art in themselves....
                      ATB.
                      • BarryW
                        • Jul 2011
                        • 6028
                        #56
                        I have fitted the undersides of the wings. Only a minor issue with a piece under the fuselage, a little light sanding was needed. It was useful to have left a little ‘play’ in the rib sections.
                        [ATTACH]436395[/ATTACH]
                        [ATTACH]436396[/ATTACH]
                        [ATTACH]436397[/ATTACH]
                        [ATTACH]436398[/ATTACH]
                          • 15722
                          Hi Barry
                          Coming together a real treat. Having the cockpit completed and presumably prone to damage it must be awkward to work on the underside, model upside down.
                          • BarryW
                            • Jul 2011
                            • 6028
                            #58
                            I have attached the undercarriage. Beautifully engineered.
                            [ATTACH]436414[/ATTACH]
                            [ATTACH]436415[/ATTACH]
                            [ATTACH]436416[/ATTACH]
                            • Gern
                              • 9220
                              #59
                              Looking good as usual Barry.
                              With regard to the level of internal detail, lots of armour kits now come with full interiors which can only be seen through hatch covers etc. I see no reason why aircraft shouldn't work the same way.
                                Barry,
                                I can certainly see now why Zoukei Mura models are priced the way they are - those internal wing structures are impressive!
