just brilliant
Zoukei Mura Hs129B-2/ RIII, 1/32 scale.
I have done an overall coat of gloss varnish. With lacquer varnishes, over lacquer paints, you need to apply it in very light mist coats over several passes. Whatever you do it is important not to lay down a heavy wet coat or you are asking for trouble.
As the next process is quite aggressive I will leave the varnish to cure for several hours. Normally you are set to go within 30 minutes with lacquers. Next I will be applying enamel washes, it is the removal of surplus with white spirit that is aggressive.
[ATTACH]440282[/ATTACH]Attached FilesComment
That is looking sharp Barry. The masked markings are great but those walk way markings are excellent.Comment
I have done the enamel pin washes and I am leaving the model overnight before applying the first Matt coat.
[ATTACH]440444[/ATTACH][ATTACH]440445[/ATTACH]Comment
My first matt coat now done. I actually used the MRP Semi-Matt as I find it gives the perfect surface for the next weathering processes. The final Matt coat will be a full matt and will done after streaking and applying exhaust smoke.
[ATTACH]440485[/ATTACH]Attached FilesComment
I have done some pigment weathering, streaking with weathering pencils and sprayed exhaust soot. That was followed by a final matt coat.
[ATTACH]440549[/ATTACH]
[ATTACH]440550[/ATTACH]
Now into the final steps starting with the application of metal powders, oil and kerosene leaks and then until final fittings. I might even get it finished tomorrow, definitely by Friday.Comment
I have done some work on the exhausts using Tamiya pigments. Still a bit of blending to do…..
[ATTACH]440611[/ATTACH][ATTACH]440612[/ATTACH]
I will get on with more weathering and expect to finish by the weekend.Comment
A quick peek at the completed model. I will do a separate completed thread tomorrow using my new photo booth…
[ATTACH]440625[/ATTACH]
This model is not the easiest but it is certainly not a hard build. This one really want to come together and is a real pleasure start to finish.Attached FilesComment
