Blackjack.
  • Mark1
    • Apr 2021
    • 4156
    Blackjack.
    Tupolev tu 160 Russian supersonic bomber zvezda 1/144.
    This looks like a pretty straight forward kit, wings can be set in three different positions, test fit of the fuselage looks good,a couple of sink marks on the top which I may or may not do anything about,only real issue I can see is the wings are a bit banana looking so they are clamped up and will be spending some while on a radiator,cockpit done and painted but to be honest the windows are so small you probably wouldn't notice if it wasn't there at all.[ATTACH]435513[/ATTACH][ATTACH]435511[/ATTACH][ATTACH]435512[/ATTACH]
  • yak face
    • Jun 2009
    • 13870
    • Tony
    Nice one mark , ive built this and its a great kit , nicely detailed and surprisingly large when done . Cheers tony
    • Mark1
      • Apr 2021
      • 4156
      A few bits to clean up but got this in primer now, went together pretty quick and easy.Click image for larger version
ID:	1160999Click image for larger version
        Mark,
        got this in the stash, and did quite a bit of research on what happens when the wings are swept back - there are precious few pictures with the vertical stabilisers deployed, - the wings are only swept in flight, so this feature is never seen on the ground ( if the wings are swept the plane tips over backwards ). I've been thinking of a way to show it in flight at supersonic speed................
        • langy71
          • 1956
          • Chris
          • Nottingham
          Dave,
          you piqued my interest with the 'stabiliser' comment, so off i went looking around the web for more info, and I now understand what you meant by it...
          I also found this huge image of it's internal layout /Build up.. she's a big bird indeed.
            It's not surprising that photos aren't common a) It's Russian! b) You have to be going pretty fast to be able to swing the wings back - and even faster to be in front of it to get a decent picture!
            • Mark1
              • Apr 2021
              • 4156
              Mark,
              Hi dave, it's a nice kit goes together well and a nice quick one, a slight bow in the wings to sort out but no big deal.
              • Mark1
                • Apr 2021
                • 4156
                Originally posted by langy71
                Dave,
                [ATTACH=CONFIG]n1161050[/ATTACH]
                They wings have three positions, there only half way back in the picture, it is big!not sure about wingspan but longer than a b52.
                • Mark1
                  • Apr 2021
                  • 4156
                  This is in colour now,need to paint exhausts and add nozzles, landing gear is together and most of the fourteen wheels painted.Click image for larger version
                    • 15785
                    Hi Mark
                    Looks to be a decent kit judging by the speed it went together. These things were huge. Are you intending to show it in flight?
                    • Mark1
                      • Apr 2021
                      • 4156
                      Hi Jim, yes a quick build,first zvezda kit I've done and will be doing more, won't be in flight,the wheels will add detail to what would be a plain looking plane otherwise as not many decals.
                      • Mark1
                        • Apr 2021
                        • 4156
                        Landing gear painted wheels going on and had a go with the exhausts and adding some blue,quite happy for a first try at it.Click image for larger version
ID:	1161165Click image for larger version
ID:	1161163Click image for larger version
                        • colin m
                          • 8784
                          • Colin
                          • Stafford, UK
                          That didn't take you long did it ? A nice build of an interesting aircraft.
                          • Mark1
                            • Apr 2021
                            • 4156
                            Decals and matt coat applied.Click image for larger version
                              • 15785
                              Looking good. Nice clean build.
