Rick’s 1/48 ICM Dornier Do17z-2
    maybe you over estimate my free hand airbrush skills Jakko.
    Possibly Though it’s not hard to keep paint off the underside of the wing — just make sure you always spray from above
    In any case, when I look at the bottom drawing, it has me wondering if the camouflage would have been that neat IRL. Which is to say, I can’t really imagine the ground crew doing as neat a job painting the plane out in some snowy field in Russia at −10°, as they would at a proper airfield back in Germany before the war. Freehand spraying seems more likely than masking everything up to get those neat, hard edges.
    • stillp
      • 8093
      • Pete
      • Rugby
      #17
      If their distemper was anything like the one I've used, I doubt if it would spray well. Probably just chucked it on from a bucket and spread it out with whatever was available - paintbrushes, brooms, rags.
      • Waspie
        • Mar 2023
        • 3488
        • Doug
        • Fraggle Rock
        #18
        Hands!!! That’s we used when we deployed to Norway in a rush!!! Loverly stuff, washed off with a good scrub.
        • rickoshea52
          • Dec 2011
          • 4076
          • Rick
          #19
ID:	1219492Click image for larger version
ID:	1219493Speckles on! The airframe stencils still need doing though. I used the kit decals, they took a while to lift from the paper. The swastika came from a generic sheet of varying styles for different aircraft.
          • Mark1
            • Apr 2021
            • 4156
            #20
            Looking good
            • flyjoe180
              • Jan 2012
              • 12390
              • Joe
              • Earth
              #21
              Looking sharp Rick, very nice
              • rickoshea52
                • Dec 2011
                • 4076
                • Rick
                #22
                White camouflage applied over AV chipping solution and maskol covered decals. I tried free hand for the upper/lower demarcation lines - let’s see how that works out later.
                • rickoshea52
                  • Dec 2011
                  • 4076
                  • Rick
                  #23
ID:	1220199Click image for larger version
ID:	1220200Maskol off and the chipping effect scrubbed off.
                  • rickoshea52
                    • Dec 2011
                    • 4076
                    • Rick
                    #24
                    Decals revealed and a pin wash applied for the panel lines. Tonight I did a bit of work on the exhaust staining using weathering powders. Trying to find reference photos of how this style of exhaust deposited staining was difficult so I just went with what looked right. Not forgetting the landing gear doors.
                    I think this might still need a wash of very thinned white to mute the starkness of the decals and visible under coat.
ID:	1221231Click image for larger version
ID:	1221232Click image for larger version
ID:	1221233Click image for larger version
                      • 18266
                      That came out pretty good.
                      • rickoshea52
                        • Dec 2011
                        • 4076
                        • Rick
                        #26
                        A little bit of mud. I. imagining this kite as operating from a muddy grass airstrip.
ID:	1222298Click image for larger version
ID:	1222299Click image for larger version
ID:	1222300Click image for larger version
                        • scottie3158
                          • 14201
                          • Holbeach
                          #27
                          Rick,
                          Some very nice touches on an already great build.
                          • The Smythe Meister
                            • Jan 2019
                            • 6248
                            #28
                            Rick,
                            Couldn't agree more, superb stuff :thumb2:
                            • flyjoe180
                              • Jan 2012
                              • 12390
                              • Joe
                              • Earth
                              #29
                              Great attention to detail Rick
                              • rickoshea52
                                • Dec 2011
                                • 4076
                                • Rick
                                #30
                                How do you get the wheels on without damaging the painted tyres?
                                If only a wheel change was this easy in real life! Gently squeeze the shock struts at the top to open out the axle end.
                                Easy when you’re a landing gear expert (ahem!).
