Airfix 1/72 Mosquito New Tooling
  • Charlie Delta Foxtrot
    • Jan 2021
    • 383
    Onwards chaps! My eyes really struggle with these 1/72 planes but for some reason I can’t resist buying them. So, Mossie time!Click image for larger version
ID:	1161241Click image for larger version
ID:	1161242Click image for larger version
ID:	1161243Click image for larger version
  • Mark1
    • Apr 2021
    • 4156
    Good start.
      • 18903
      Nice detail in there for 1/72.
      • Mickc1440
        • 4775
        Great start, I think i'd be struggling with that detail
        • adt70hk
          • Sep 2019
          • 10409
          Russell
          Looking good.
          Out of interest, which version is it? I'm doing my utmost to resist buying this one...
          1/72 De Havilland Mosquito A04023 Airfix Scale Model Shop UK, 5* Customer Service, Fast Delivery, Reward points on every order
          ATB
          • colin m
            • 8750
            • Colin
            • Stafford, UK
            Looking nice Russell.
            I'm ok with 1:72 at the moment, but am thinking, build 1:72 now, saving the bigger scales for the future.
              • Jan 2021
              • 383
              Originally posted by adt70hk
              Russell
              Looking good.
              ATB
              It is! it’s a great kit by the way, theyve done a great job here. i’d say; don’t delay and give in to your instinct!
                • Jan 2021
                • 383
                Update! Such a good kit this, I really wanted to ensure that the fuselage was tight so that beautiful smooth appearance would be easy to emulate. A little sanding and fine, no filler required! Also bought some of AKs 3rd gen acrylics to do the paintwork, will see how they work today. Click image for larger version
ID:	1161636Click image for larger version
ID:	1161637Click image for larger version
ID:	1161638Click image for larger version
ID:	1161639Click image for larger version
ID:	1161640Click image for larger version
                • yak face
                  • Jun 2009
                  • 13840
                  • Tony
                  Looks a lovely kit russel , nice primer job . Am I right in thinking Airfix have provided mask covers for the wheel wells !? If so then they should be applauded , cheers tony
                    • 18903
                    Agreed, lovely prime and preshade there Russell.
                    • adt70hk
                      • Sep 2019
                      • 10409
                      Hi Tony
                      At the risk of stepping on Russell's toes, they have indeed.
                      Also, according the reviews I have read, the mounting points for the suspension in the wheel well are actually also designed to work as a jig to help you construct it it after which it can be removed for painting.
                      These are a couple of the reasons I really am considering getting this. The reviews for this kit I'll pretty much unfailingly good.
                      Russell - apologies for butting in! That really is coming on beautifully and that pre-shading looks like it's going to work a treat. Keep up the great work.
                        I like those MASK parts. I just wonder why they didn’t provide one for the cockpit copy too — maybe the designers assumed everyone glues that on before painting?
                          • Jan 2021
                          • 383
                          Yes they have! and the closed bomb bay is one piece so can be used to mask if you’re doing an open bay, which I am.
                            • Jan 2021
                            • 383
                            Therein lies a tale…I was masking the canopy myself but because you have gaps either side it’s quite flimsy and cutting one section I put too much pressure on and snapped it. If I hadn’t, you’re right, it would be glued on now. I am going to have to use the bubble top replacement canopy which isn’t strictly Mk XVI but does appear on the B35. History buffs will notice. But i am also waiting for a masking set now too so as to avoid risk is snapping this one as well.
                              • 18903
                              Great stuff. I hope they continue that with future releases, it’s a worthwhile addition that improves the build experience.
