Zvezda 1/144 Beriev Be-200ES Jet Amphibian
    As I'm waiting for paint to dry on my T-90MS, I've been deciding what to build next. I've decided on another Zvezda model:
    One of the few jet flying boats ( and amphibian ) used as a fire bomber, and emergency response unit.
    Sprue shots
ID:	1161835Click image for larger version
ID:	1161834Click image for larger version
ID:	1161833Click image for larger version
    All look very crisp, with fine detail, although how visible panel lines would be in 1/144 is debatable!
    Decals
    Two marking options - one military - the other 'civilian'
ID:	1161837Click image for larger version
    I reckon the civilian version looks better!
    It's only a comparatively simple model - 60 parts - the main challenge will masking.
    Construction will start shortly
    • 18901
    Interesting subject Dave. Have fun with it.
      That looks interesting, and a type of plane you don’t really see anywhere outside Russia.
        One has been fighting wildfires in Greece ( August 2021 ), and they have been used in Turkey, Spain & Portugal
          I meant that as “being manufactured” outside Russia This type of plane really only comes from there, as far as I know,
            Off we go.............
            Unlike a lot of 1/144 aircraft, this does have transparencies for the side windows - I painted the back side of them black, then primed & basecoated the area around the windows white.................
            I added the windows & I'll put a mask over the outside, to protect them, as there is a bit of masking needed near them. The engine pods & wings assembled - perfect fit, just a little TET run into the joints. Cockpit assembled - although you won't see much. Needs 10g of weight adding, but plenty of room!
            I'm going to work out when I have to start masking - the paint masking has to follow the decal cheat lines, so it'll need a bit of careful laying out & measuring.
              • 18901
              Nice start Dave. Looks like it could be a fairly quick build.
                • 15687
                Hi Dave
                That's some aircraft. Very unusual.
                  Just about ready to start the painting process.....................
                  I'll stuff the wheel wells & cockpit with tissue - those areas can wait, until after decals are applied ( the main gear legs are close to the side of the fuselage ). The wings will be sprayed separate from the fuselage - I want to mask the fuselage for white/grey/blue & they'd just get in the way. The joint looks very good, so shouldn't be a problem joining the two together. The same goes for the engine pods. although, I'll brush paint those - too small/tricky to mask. Just used a smear of filler on the nose, but that will be it I think, I can put the tube away.
                  Going well - the real test will be how the decals handle & fit................
                  • outrunner
                    • Apr 2019
                    • 2420
                    Fast work Dave, looks to be a nice model.
                    Andy.
                      I would say that the Be200 falls into the category 'too big in 1/72' & 'too small for 1/144' It's a simple model - 10 of the 60 parts are the control surface actuator covers! It also means that you can't misalign any of the parts.
                      • yak face
                        • Jun 2009
                        • 13840
                        • Tony
                        Nice work dave , so how big is it ?
                          220mm wingspan, 230mm long & quite dainty!
                          • yak face
                            • Jun 2009
                            • 13840
                            • Tony
                            Looks a lot bigger in the pics , a testament to the fine tooling
                              Taking a lot more light coats of white to get a good finish than I anticipated
                              All the big bits dry fitted - the paint does need scraping away from the mating surfaces, the joints are that tight!
