I have been itching to have another go at one of these it's not going to be my usual out box build as I will having a go putting in wear and tear and something I don't normally do witch is pre shading here's the results on engine and one side of the rear bulkhead.
And the wing underside
All the cockpit frames are painted weathered and ready to be assembled and I finally have a use for my seat belts that is all the extras I will be using the rest of the kit is out of the box.
Whilst waiting for my magazines to arrive I have done some more on this build.
I have squeezed the engine and cockpit in fuselage halves and started the weapons bay.
