Academy P40E Warhawk 1/72
  • yak face
    • Jun 2009
    • 13841
    • Tony
    Heres a kit ive had a while and I just fancied a nice simple build between the more involved ones . Its a beautiful little kit which ive made before ( over ten years ago !! See here https://www.scale-models.co.uk/threa...markings.7741/ ) and I intend doing it in the RAAF scheme ,of sqn leader Richard Creswell. Ive got some etched seat belts for it out of the spares , not entirely correct type but so what . Heres where im at so far . Click image for larger version
ID:	1161883Click image for larger version
ID:	1161884Click image for larger version
ID:	1161885Click image for larger version
ID:	1161886Click image for larger version
ID:	1161887Click image for larger version
ID:	1161888Click image for larger version
ID:	1161889Click image for larger version
ID:	1161890Click image for larger version
ID:	1161891Click image for larger version
ID:	1161892Click image for larger version
ID:	1161893Click image for larger version
    • 15704
    Hi Tony
    Looks nice. It's come together quickly.
    • Steven000
      • Aug 2018
      • 2828
      • Steven
      • Belgium
      Looking forward to the next steps Tony, have fun :thumb2:
      Steven
      • yak face
        • Jun 2009
        • 13841
        • Tony
        Wing tops and windscreen now on and its had a coat of Halfords grey primer . The airframe didnt need much of a clean up , just a few wipes with the acrylic putty on the wing roots and a little filler either side of the engine where the wing bottom joined. Next I can start with the colours , which although an RAAF machine are not earth brown and foliage green . This well researched machine was finished in the du pont equivalent colours for RAF aircraft at the Curtiss factory so good old dark green and dark earth but with a sky grey underside. Click image for larger version
ID:	1162541Click image for larger version
ID:	1162542Click image for larger version
          • 15704
          Hi Tony
          Looks good with it's coat of primer. No issues to correct, a credit to your build.
          • adt70hk
            • Sep 2019
            • 10409
            Looks nice!!
            As you say is sometimes nice just to do a simple build.
            ATB.
              • 18907
              Nice quick job so far Tony. Looking very fine under primer. Office looks great as well.
              • flyjoe180
                • Jan 2012
                • 12407
                • Joe
                • Earth
                Nice to see another 1/72 Academy kit being built. They may not be the most accurate kits at times, but there's lots of scope for the experienced modeller to create a great result. I have this kit too. Looking great so far Tony :thumb2:
                • yak face
                  • Jun 2009
                  • 13841
                  • Tony
                  Camo now going on . Vallejo sky grey for the undersides and Hataka RAF dark earth and dark green for the top colours .pics to follow soon as they can get resized
                  • yak face
                    • Jun 2009
                    • 13841
                    • Tony
                    [ATTACH]438048[/ATTACH][ATTACH]438049[/ATTACH][ATTACH]438050[/ATTACH]Pics of the paint
                    • yak face
                      • Jun 2009
                      • 13841
                      • Tony
                      Masking off , decals on and a flat coat applied ( Tamiya xf86 flat clear)
                      Once this has cured its on with all the bits and bobs Click image for larger version
                      • Mark1
                        • Apr 2021
                        • 4156
                        It's looking well :thumb2:
                        • minitnkr
                          Charter Rabble member
                          • 7540
                          • Dayton, OH USA
                          Very clean build & finish. Dad & Grandpa built these at the Curtis Wright Plant next to Buffalo airport through the war.
                          • yak face
                            • Jun 2009
                            • 13841
                            • Tony
                            Wow cool fact paul , they probably had a hand in this very aircraft :thumb2:
                              • 22770
                              Just seen this one Tony, great work so far.
