Tamiya 1/48 F16C Fighting Falcon Block32
  • Mickc1440
    • 4775
    #46
    Still waiting for the weather to improve so I can start on the big paint jobs. Still undercoating small bits but decided to crack on with the tail fin. This is a stand alone assembly that attaches to the model on two metal rivets using rubber grommets. One side done and hopefully the other later when it’s all dry then there’s a clear part to go on then I just need to make up some very thin little probes, I think they are,to attach, same on the rear fins too.
    • boatman
      • Nov 2018
      • 14474
      • christopher
      • NORFOLK UK
      #47
      OH love that tail fin Mick very well done look superb
      chris
      • Mickc1440
        • 4775
        #48
        Now the storms have abated I managed to get some spraying done. All three main colours done so on to the more detailed jobs. Unfortunately my phone camera lightens the paint a bit too much, will try again when I get a bit further.
        • Mini Me
          • Jun 2018
          • 10711
          #49
          Looking good so far Mick. :thumb2:
          • JR
            • May 2015
            • 18273
            #50
            Yes, looking good as Rick says, bet your pleased to be able to get some paint on Mick.
            • yak face
              • Jun 2009
              • 13840
              • Tony
              #51
              [ATTACH=CONFIG]n1169202[/ATTACH]
              When you say thin little probes do you mean the sets of three on the rear edge of the fin and elevons ? If so they are the static dump wicks , theres three on each wing too . Are they included in the etch set mick ?if not I usually use toothbrush bristles stuck on with a tiny dab of CA ,then when dry a little blob of pva on the end . Looking mighty fine now , cheers tony
              • adt70hk
                • Sep 2019
                • 10409
                #52
                Mick,
                That is coming on very very nicely. Love the tailplane!!
                Keep up the great work.
                ATB.
                • Mickc1440
                  • 4775
                  #53
                  Hi Tony, yes they're the ones, I saw a guy fitting them on a build blog, there's nothing in the kit or my etch but you can see on the model itself where they are supposed to fit so I too will improvise.
                  Rick JR and Andrew, many thanks for looking in.
                  • Mickc1440
                    • 4775
                    #54
                    Caught an old fashioned cold and it floored me for four days so lost all that time at the desk. Since managed some progress so I now have the wheels on, endercarriage doors fitted and clear coat on ready for the decals.
                    • boatman
                      • Nov 2018
                      • 14474
                      • christopher
                      • NORFOLK UK
                      #55
                      HI Mick lovely job so far but what are them pins for on the tail ?
                      chris
                        • 15696
                        Hi Mick
                        Hope the cold's better. Trouble these days is every cough and sneeze and we think "is it???" :rolling:
                        Falcon is looking good. I like the tail. Interesting way of fixing it. Nice looking paint job. Decals will make this pop.
                        • Mickc1440
                          • 4775
                          #57
                          chris
                          The tail fin doesn't glue on, those pins locate in rubber grommets inside the fin. There are also some for the belly tank and wing tanks. The 1/32 scale F-16 I've just bought has quite a few more of these so you can store the model if there's no room to display it, it's box converts into a storage box.
                          • Geoffers
                            • Jan 2017
                            • 1700
                            • Geoff
                            Looking very nice Mick :thumb2:
                            Geoff.
                            • Mickc1440
                              • 4775
                              #59
                              After over 2 hours work I have most of the decals on. Apart for one around the refuelling housing and the airforce insignia everything else is tiny. Unfortunately 2 of the most prominent cockpit side decals just disintegrated in the water, I’ve sourced some replacements which should arrive in the next couple of days. I can then give it another clear coat and do some weathering.
