Airfix 1/48 Bristol Blenheim Mk1
While MDP applied to the seams is drying I have worked on the undercarriage. I should have taken some pics at an earlier stage but I can report that the fit and engineering is excellent. Here is a u/c assembly fitted into the engine nacelles ready to paint, something I will do before I cement the top of the wing into place. The wings have some warping, but again not a problem to rectify on a small 1/48 kit
I have been working on the engines and wings while between filling and sanding sessions on the fuselage seams.
The engines are nice but the panels are not great fit and they needed some filling and sanding. One join between two panels is particularly problematical to sand due to some raised detail. But it all came together in the end.
Both wings had some warping issues, one worse than the other. While manageable in this scale it would have been a massive problem with a larger scale. It really proves my point that this horrible soft Airfix plastic is unsuited for large scale kits. On the wing that had the most severe warping a dry fit shows that fitting the aileron will need some sanding and fettling.
This is brilliant, would love a setup like this, may I ask where you bought that setup from, did you get this online or self built?Attached FilesComment
Looking like a very nice kit with some good surface details.
A shame about the warpage in the wing parts. But is this only an Airfix issue? Serious question.
I wonder how other European brands plastic compare. Is the real culprit an EU directive that has forced changes to ingredients in the plastic. I recall some other brands also have quite soft plastic as well.Comment
Airfix are not bound to obey EU Directives of course and neither is India where Airfix kits are manufactured. I have not found this soft plastic on any other brand I have built.Comment
Airfix provide a really nice building jig for the turret, something I have only seen on some high end kits before. Here it with with the first couple of parts positioned.
and more
All done and off the jig
Also I masked the wing tip lights. These masks are odd in that they are over sized and hang over the edge and donโt fold over.
Engines fitted to wings, nice fit.
Barry,
Looking good I don't know how soft the plastic is but the IBG kit I am building is also soft and has the same appearance as your Airfix plastic.Comment
