I had an accident, dropping the model, while trying to get into awkward places. The model rattled when I picked it up and found that the very nice instrument panel had broken away.
I waited until I had done the final matt coat to remove the masking and to see if I could fit it back in through the gap I left in the top. Sadly there was no way I could find to hold the piece in the right position to slot it through the gap and over into position. In the end I decided to seal up the canopy without the i.p. Annoying, I just won’t have to look closely into the cockpit….
Strangely this is the second time in a row where an internal part came loose. Both times it was where I used superglue to fix painted parts into place. I won’t do that again….
Anyway I have finished the weathering and final fittings. Here is how she looks now. I will do a completed thread soon.
Photos still not positioning in the correct perspective even where it looks OK on the phone.
Bummer! CA is brittle and breaks very easy if shocked but I guess you know that by now. I hate the stuff!
Regarding the photos being in the wrong orientation, Which way are you holding your phone. Up-down as if talking of sideways?
A solution is in sight but will happen after John has moved the shop to another server...
