1/48 Esci Henschel HS 129 B-3
    I'm starting up the Hs129 ,going to do the B-3 version. Dry fit looks so,so its going to need some filler here and there. Especially the wing root areas.
    Very stark office but its going to be a closed canopy anyway so not much at all will be seen
    I have a pilot left from another build so an in flight wheels up build is the plan
    I've gotten the wings and tail feathers glued and started filling the gaps with Squadron putty. The plastic on this kit is very soft so I did'nt want to use Ca it would be to hard me thinks.
    I pulled off the protective tape while the filler was still wet
    then used some acetone on a 'Q' tip to blend it, I'm hoping to cut down on the amount of sanding and saving as much surface detail as possible
    on to the tail feathers !
    good job so far... keep up good job
      • 22770
      Nice start Tray
      • Dave W
        • Jan 2011
        • 4713
        Looking good Trey.
          Looking good so far..
          • Vaughan
            • Apr 2011
            • 3174
            Another great build on the way Trey!
            Vaughan
              Thanks Fellas The sanding and blending done and the pilots ready
                Looking good so far mate. Keep it up.
                Kresten
                  Nice one Trey, looking forward to the finished product.
                    Nice work Trey, I especially like the paint work on the Pilot. Cheers Derekkkk
                      Kresten,John,Derek,thanks appreciate the kind words.I was'nt looking forward to having that long barrel in the way for the rest of the build
                      The barrel glues to the fuse inside the farining, so in order to get around it and still have the fairnig in place I decided to cut the barrel . I measured the barrel so the cut area would be well hidden inside the fairing
                      A small wire will help align and hold it after the painting is complete
                      test fit looks good
                      Fairing is now glued into place and the landing gear door areas have been sanded and the tab holes filled with styrene scraps
                        Good thinking Trey, i to hate things that stick out & get in the way, i'll remember this one for next time.
                        Looking forward to more pic's.
                        Have fun
                        • stona
                          • Jul 2008
                          • 9889
                          Completely missed this one! Nice work and an interesting subject.
                          I put a bid in on Pegg's Hs129 book on evilbay recently.A waste of time as it will end up going for the best part of 200 quid....WTF!!!!!
                            Thats a great idea, Will come in handy! Thank you.
                              John thanks,Steve I'm geussing 200 quid is a tidy sum? and thanks. James thanks hope it helps !I 've made a little headway and sprayed some base black and then the rlm 65
