Trumpeter 1/144 Avro Vulcan
    James,
    think you've got enough clamps? - If not, I know where you can get one of these.........................
    Dave :smiling5:
    • Ancientmariner
      • Feb 2018
      • 859
      #17
      Now that's a clamp!!! What tonnage force is it?
      And actually I ran out of clamps lol
        I think it said 800 tonnes! - ran out of clamps? doesn't your missus have pegs to put the washing out?
        • Ancientmariner
          • Feb 2018
          • 859
          #19
          Actually the pegs maybe better as these ones I'm using keep slipping off and the pegs have rubber grips.
          Just dug 2 trumpeter lightnings out for construction next and also a hasegawa sea harrier set of 2 as I'm currently listening to harrier 809 audio book as I've just finished lightning boys.
          • Ancientmariner
            • Feb 2018
            • 859
            #20
            Base coat done.......
            • Geoffers
              • Jan 2017
              • 1706
              • Geoff
              Great progress :thumb2:
              Geoff.
              • Ancientmariner
                • Feb 2018
                • 859
                #22
                Anti-flash white on the belly done and a layer or two of varnish already down. Now just for the top sides in grey green camo scheme.
                As always having issues with masking tape removing paint. I suspect the surface wasn't 100% clean.
                • Mickc1440
                  • 4779
                  #23
                  RAF Finningley in the 60/70s Battle of Britain Air displays - 3 Vulcan scramble - one lifting off, next halfway down the runway & the last just opening his throttles, the ground shook - the air crackled - and the smell of burnt fuel! I first went in 1962 - the last time in 1977 ( a few years missed, though, either at college, or at sea! )
                  We lived 30 minutes from Finningley and was lucky enough to be there for the last Vulcan scramble, a memory ingrained for ever
                  • JayCee
                    • Aug 2019
                    • 1132
                    #24
                    I spent time working at RAF Akrotiri when the Vulcan was based there. As there was one in the air 24/7 I saw more than a few take-offs and landings. If you have ever seen a pilot treating a Vulcan like a Tiger Moth, doing aerobatics, you will never forget it. Simply mind blowing !!
                    John.
                      Yep,
                      been there done that - ruined a Sea Vixen, white paint came off in huge patches! Now, I always prime & allow to dry for 24hrs before masking & overspraying! Takes more time,but saves the bad language!
                      • Ancientmariner
                        • Feb 2018
                        • 859
                        #26
                        Well I gave it two coats of primer Dave in the black. That was Vallejo primer so all I can assume is a. The masking tape is c**p or b. There was grease on the surface before priming which is possible. Annoy as hell though.
                        • stillp
                          • 8096
                          • Pete
                          • Rugby
                          #27
                          Vallejo primer doesn't seem to have a good reputation James. I've only used it once, and had some problems with paint coming off with the masking tape.
                            I've moved onto using AK primers, and not had any lifting problems so far............
                            • Ancientmariner
                              • Feb 2018
                              • 859
                              #29
                              I have actually a little bottle of AK, may get some more then in other colours.
                              I did however mask and spray sea great on top today. Using my new mixing bottle and thinning paint an awful lot more than before has changed the result so much. I tried to show panel shading but hasn't really shown up in pics too well.
                                James,
                                rather than have a lot of primers, I generally use black, light grey, or olive drab primers only ( 60ml bottles ). - If I have a bright orange/fluorescent red finish, I do use a red primer ( 17ml ).
