1/48 Dornier Do17Z-2 ICM
    • 15696
    Hi Barry
    Having pain in your back is debilitating and very frustrating. Hope it improves soon and you have a good break at Easter.
    • JMARC
      • Sep 2008
      • 352
      #17
      LLLLLLLLLLLooking pretty good so far !...Keep it up !
      • adt70hk
        • Sep 2019
        • 10409
        #18
        Barry
        Just had a catch-up; it's coming on very nicely. Sorry about the back, hope it's getting better.
        It was interesting to read the discussion you and Dave had about the ICM dates and their improvement, as I've just acquired a one of their 1/72 Dornier Do 215B-5. It is an update of a 2017 215B-4 new tooling. It's got very good reviews and so it's good to hear it's after 2015 - not that that is a guarantee as you say.
        All the best.
        • BarryW
          • Jul 2011
          • 6012
          #19
          I have fitted the wing but there is a lot of filler and sanding needed. It is mostly done but it need a little more treatment on the upper forward join. I applied some Mr Dissolved Putty in a few spots and it now needs a few hours to cure properly.
          I have also been working on a number of sub assemblies. No real issues with any of them.
          Once this wing join is sorted and rescribed progress should pick up a bit of speed.
          • JMARC
            • Sep 2008
            • 352
            #20
            NNNNNNNNNNNNeat !
            • adt70hk
              • Sep 2019
              • 10409
              #21
              Coming on nicely Barry.
              ATB.
                • 15696
                Hi Barry
                Back at the bench so hopefully your back is better. Filling wing roots is always a pain. It's not just getting a nice finish but rescribing lost detail.
                • BarryW
                  • Jul 2011
                  • 6012
                  #23
                  The airframe has progressed and the stabs are now fitted.
                  I have painted and weathered the components for the wheel wells.
                  And made a start on the props
                  The engines sprayed and dry brushed
                  • Mickc1440
                    • 4775
                    #24
                    Just caught up with this build Barry and you're making a great job of it.
                    • adt70hk
                      • Sep 2019
                      • 10409
                      #25
                      Coming on very nicely Barry.
                      Well done.
                        • 18903
                        Looking very tidy Barry. Nice to see a Blitzkrieg era flying pencil on the go.
                          • 15696
                          Hi Barry
                          Coming on a treat. Up to your usual high standards.
                          • JMARC
                            • Sep 2008
                            • 352
                            #28
                            NNNNNNNNNeat
                            • BarryW
                              • Jul 2011
                              • 6012
                              #29
                              I have been working on the engine nacelles.
                              The engineering is a bit over complicated, needlessly so. First you build a ‘box’ to form the wheel well which incorporates cross struts. Below shows three sides installed with one to go. The fit is fine if tight.
                              Then you cement the nacelles around the box
                              Again the fit is Ok, if tight.
                              I cemented the front first and, when dry, will bring the rear in together to cement.
                              A fair bit of filling and sanding is going to be needed on the joins.
                              • adt70hk
                                • Sep 2019
                                • 10409
                                #30
                                Coming on nicely Barry...but over complicated as for say.
