Looks like a solution looking for a problem to me. Nice work though….
1/48 Dornier Do17Z-2 ICM
But Alan, what you describe as over engineering of Zoukei Mura kits is to provide high levels of detail and great fit while offering you options. This kit is over engineered to no purpose, normal detail, normal fit and no options.Comment
I am ready to spray the first black primer coat. I do expect it to show up a few flaws that will need treatment.
The pit was easy to mask off. I fixed the canopies temporarily with Micro Liquid Tape which, when the painting is done, enables them to be easily removed for the fitting of the guns.
The canopies are a perfect fit
The wheel wells were masked in the normal way using blue paper and tape.
I have sprayed some degreaser which I will leave to dry before painting.Comment
