Looking really fine Peter. keep forgetting this is only 1/72 scale. The splinter Cam is probably easier with tape rather than masksโฆ.but it is only the edges that need burnishing down I suppose.
Dogfight double pt. 1: Stuka
Removed the camo masks and most of the tape masking
I'll remove the masking from the canopy and the bomb sight window after I've sprayed the matt coat.
A couple of touch-ups needed, but not too bad, and I need to finish painting the u/c legs with a brush - they were too difficult to mask and spray. Tailwheel is a brush job too.
Also finished the stripe decals on the bombs, they're currently drying after a coat of Microsol.
PeteComment
That looks really good Peter. The white came out really well too. Usually it doesn't cover as nice as one would like it too. Good luck with the bombs!!!
AllenLife's to short to be a sheep...Comment
Underside decals on:
Fitted the centreline bomb and it's trapeze. Had to touch up the paint on the trapeze and spotted a slight mistake...
The masking is still on the bomb sight window! That'll be a bit tricky to remove without breaking the bomb trapeze, which I already broke while trying to clean up the mould seams. :sad:
Might as well fit the rest of the bombs before I start on the rest of the decals.
PeteComment
Most of the decals now on, but I need some advice from the experts. I'm adding aftermarket swastikas, as I think German aircraft of the Nazi era don't look right without. The ones I'm using are in two parts, one white, and a black one slightly smaller, the idea is to put the black swastika on top of the white so a white border shows. My only experience with two layers of decals was jsut a separate red dot on a roundel. but this is a larger decal, more fragile, and needs to be in the correct orientation as well as centred perfectly. I'm wondering if I should give the white a gloss varnish coat before trying to add the black one, to make it easier to slide as well as reducing the chance of the white getting damaged.
What do you say folks?
PeteComment
