Airfix 1:72 Curtis P-40B Warhawk
  • Valeron
    • Jan 2022
    • 944
    • Mike
    • St Albans
    I've recently just completed my first model - A 1:72 Spitfire Mk. Vc.
    I was then going to start a Tamiya T-62 kit I have but as I've signed up for the Mossie Group build in July and I'm new to all of this, I thought I be better of practising with another 1:72 aircraft as that is what I'll be building in the GB.
    I will be building this out of the box and hand painting using Vallejo paints.
ID:	1174569Click image for larger version
ID:	1174570Click image for larger version
ID:	1174571Click image for larger version
    • 15736
    Hi Mike
    Strike while the iron's hot - straight on to another plane :thumb2:
    Looks a nice kit which judging from your Spitfire you'll make a great job of.
    • adt70hk
      • Sep 2019
      • 10422
      Cool!
      • Lee Drennen
        • 7711
        Mike that’s a nice kit. I’ll be following along I have that same kit I hope to build some day.
        • langy71
          • 1950
          • Chris
          • Nottingham
          Just looking at the dates on the aircraft description..(on the box), I'm presuming this is one of the 12 aircraft that actually got off the ground and then attacked the Japanese attackers during the Pearl Harbour attacks?
          • JMARC
            • Sep 2008
            • 352
            CCCCCCCCCCCOOL ...Go,go,gooooooooooo !
            • yak face
              • Jun 2009
              • 13847
              • Tony
              Great choice mike , its a lovely kit that builds up without any problems . Only thing to watch out for is dont get too much glue on the canopy rear panels as it can wick under due to the small clearance ( use pva type stuff too ) cheers tony
                • 22771
                Just pulled up my chair Mike.
                • Valeron
                  • Jan 2022
                  • 944
                  • Mike
                  • St Albans
                  Bench time has been limited but I'm back on it now. The cockpit has been assembled and the fuselage started.
                  I'm currently struggling with fitting the upper wings. Something isn't quite right but I will prevail.
                  Also trying to work out what clear part 4 is. I'm going mad and can't see it on the intructions at all.Click image for larger version
ID:	1175334Click image for larger version
ID:	1175335Click image for larger version
ID:	1175336Click image for larger version
ID:	1175337Click image for larger version
                  • Allen Dewire
                    • 4741
                    • Allen
                    • Bamberg
                    Just got in on this Mike and it looks like you are having fun here. Could the clear part maybe be the gun sight??? it looks too big for a light of sorts and it's only one piece...Good luck fitting the wings....
                    Allen
                      • 15736
                      in my limited experience of aeroplane building the fit between wings and fuselage is always tricky. As you say though you'll sort it :thumb2:
                      Could it be a part that is not used for this kit??
                      • Allen Dewire
                        • 4741
                        • Allen
                        • Bamberg
                        Hey Mike, Check out step 16 on the instructions, that should be your piece 4c.....Looks like a landing clearance light......
                        Allen
                        • Valeron
                          • Jan 2022
                          • 944
                          • Mike
                          • St Albans
                          Allen
                          Brilliant. Spot on. You're good.
                          I'd looked through the instructions, of which there are not many pages, so many times and there it is as clear as daylight at step 16.
                          Thanks.
                          • Allen Dewire
                            • 4741
                            • Allen
                            • Bamberg
                            I know that feeling so well Mike. You search and scan and search, but you can't find it. Glad to help, oh, and sometimes a beer helps too.....Drive on and have fun Sir!!!
                            Allen
                            • JMARC
                              • Sep 2008
                              • 352
                              NNNNNNNNNNNeat !
