Antonov An-2 (Revell, 1/72)
    • 22770
    #16
    A great start Roman and some good added extras
      cockpit glued into fuselage and fuselage together... also lower wing.
      dry fit
      it's not to bad at all... will be little of putty and sanding but nothing special...
        • 18269
        Coming along nicely Roman.
        IanM
        • homechild
          • Oct 2010
          • 474
          #19
          It's starting to take shape Roman. Looking forward to seeing the final paint scheme.
            That looks a lovely little kit Roman. The added detail you have done is fantastic at that size. Look forward to seeing what scheme you go with.
              little dry fit of upper and lower wing
              till now not a drop of putty is used
              Roman
                Another fine looking build in the works Roman,the office looks great!
                  I have manage to do joint of lower wing and fuselage. I see same thing is waiting for me for upper wing and canopy.
                  All panels on lower wing and fuselage are rescribed.
                  Must have also putty time on engines cowel.
                  Here are some pics from my work... upper wing, canopy and engine are still on dry fit.
                  Roman
                    Looking good. That canopy looked a pain to mask! Those joins look like they will give you and the putty a good work out!
                      Here I have one tip... I dont know if any of you work like this... Tip is for filling gaps between canopy and fuselage.
                      I use WATER BASED glue for wood, who is dryed became transparent.
                      With toothpick put drops into the gap untill is filled up and little overedge and when I finish with filling gap right away moisture with mouth cotton swab (for cleaning ears - dont know on english... i think is cotton swab) and wipe away excess untill stay only ammount in the gap. After drying you will se clear transparent fiulling.
                      If neccesery replay all... because somethimes with cotton swab you clear little more from the gap.
                      Next time when I will do this I will make video tutorial
                      hope you will see different on pics and model of glue.
                      BEFORE:
                      AFTER WATER BASED WOOD GLUE:
                      and must say gap was not like before on my post, upper wing have little too mutch bended canopy, after I was glu it I see gap was not too big, but was present... arround 1/2 - 1 mmm
                      Hope I help with this tip
                      Roman
                        Thats a very good tip Roman and one I will be trying :bow:
                          yaa awsome tip and one i would never have thought of thnx roman
                            engine, upper wing and upper wing carrier are glued, all is putty and sanded and preparation for rigging is under the way
                            Thats all for today
                            Good night and cheers,
                            Roman
                              Great fix on the canopy Roman,looking sharp!
                                Looking good, what method do you use for rigging? I really need to learn how to do rigging.
