Sukhoi Su-27 Flanker B Trumpeter Scale 1:32
  • arb65912
    • May 2022
    • 202
    #181
    As some of you know I am making the model of SU-27 for X-Plane Flight Simulator and that scale model project is also a help for me to determine how to create 3D model in Blender.
    Did a lot of dry fitting to see how components go together, believe it or not, it is a BIG help for me.
ID:	1177558Click image for larger version
ID:	1177559Click image for larger version
ID:	1177560Click image for larger version
    • arb65912
      • May 2022
      • 202
      #182
      Today I was gluing together one of the missiles and what a great learning experience.
      1. I was amazed to find out that working on these little parts was actually manageable.
      I think fingers get used to handle these tiny parts and of course with the help of tweezers one can do the job (read, me as a total newbie) :smiling6:
      2. I have learned that order you glue parts is IMPORTANT, I was ALMOST not able to glue second missile stabs because of the shape and the way you need to put it into the slot.
      I managed to do it but had to bend a bit the already glued stabs, it was still wet fresh enough to give it proper angle.
      3. I am getting to know the Tamiya Extra Thin Limonene and Tamiya Extra Thin glues.
      The regular (green) Extra Thin is so fast, few seconds and the part is there, love it, except of strong odor, I actually like that smell but I know it is not the best thing to enjoy. :tongue-out3:
      With Tamiya Extra Thin Limonene, there is slightly more time for working with the parts, actually you need to wait few seconds till the glue dissolves the plastic and then press and hold for several seconds till parts stay.
      Great learning experience.
      I am pretty satisfied with the result, I even managed to glue the missile stabs kind of perpendicular to each other. :nerd:
      The fun continues!!!!
ID:	1177673Click image for larger version
ID:	1177674Click image for larger version
        Oh, that looks like fun … Each of those little fins is a separate part, and your cutting mat is marked in centimetres?
          • 18932
          Yep, one of those fiddly little jobs of which the usual build has many examples. At least Andrzej can use the cutting mat markings to make sure the fins are square Jakko……
          Making a nice job of this though Andrze. Looks like the modelling bug has bitten deep…….
          • arb65912
            • May 2022
            • 202
            #185
            I do not know; it must be centimeters. Actually, I will need to start using the cutting mat not just for cutting.
            • arb65912
              • May 2022
              • 202
              #186
              Tim, I honestly did not even think about it (using squares for alignment) but thanks for another great tip!!! :thumb2:
              Yes, the bug got me, I am looking forward each time to do some next step on the project. Thanks!
                I counted ten squares between the thick lines, which is why I asked, because it looks like you, despite being in the USA, have a cutting mat marked in real measurements Anyway, the lines can be handy for quickly measuring things out, and like Tim says, to make sure pieces are square or straight as well.
                • arb65912
                  • May 2022
                  • 202
                  #188
                  I counted ten squares between the thick lines, which is why I asked, because it looks like you, despite being in the USA, have a cutting mat marked in real measurements :smiling3: Anyway, the lines can be handy for quickly measuring things out, and like Tim says, to make sure pieces are square or straight as well.
                  After being so long (over 30 years) in USA, I got used to inches and decimal inches (work, Solidworks software) so when I was buying a mat, I just wanted it to be big enough and it is.
                  I like the idea of checking things straight and square though.
                  • arb65912
                    • May 2022
                    • 202
                    #189
                    Hello my friends!
                    No, I did not quit.
                    I was just "possessed" with DCS (Digital Combat Simulator) for few days, pretty cool. Mission Eitor is a real fun.
                    I hope I can get some more done on SU-27 this weekend.
                    I just need time!!!!! :tears-of-joy:
                    I have my SU-27 Flanker B project as scale modeling, another one for X-Plane Flight Simulator and now I discovered this DCS which is also cool. :nerd:
                    I did not retire yet and having a regular, pretty busy job makes it kind of hard to do all mentioned above, I do the best I can though. :smiling:
                      I don’t play DCS myself, but since you do, you might enjoy seeing something like this (starts at the point relevant to your model):
                      • arb65912
                        • May 2022
                        • 202
                        #191
                        He, he, he. Nice, Jakko!!! :smiling:
                          The channel this is from, Grim Reapers, has a lot of very funny DCS-based videos. Also plenty of serious ones, but as I don’t play it, those don’t interest me
                          • adt70hk
                            • Sep 2019
                            • 10433
                            #193
                            That is coming on very nicely Andrzej, although that single missile has more parts than most of my kits. Keep up the great work.
                            • arb65912
                              • May 2022
                              • 202
                              #194
                              The channel this is from, Grim Reapers, has a lot of very funny DCS-based videos. Also plenty of serious ones, but as I don’t play it, those don’t interest me :smiling3:
                              I think, I am done with DCS. It is nice and one could have fun but there are too many inconsistencies and too many things to fix so at my age I just have to concentrate on what is more fun, which is X-Plane simulator and scale modeling.
                              • arb65912
                                • May 2022
                                • 202
                                #195
                                Thank you, Andrew.
                                It is going slow but no races, it has to be fun.
                                Yes, many pieces on this project for sure. :smiling:
