Sukhoi Su-27 Flanker B Trumpeter Scale 1:32
I had a terrible time at the beginning to grab little parts with fingers, but I have to say it gets MUCH better. I wish I had a little miniature finger set though. :tears-of-joy:Comment
There’s this really neat gizmo for that:
Buy some (different brands are also available) with pointed tips and with either straight or rounded ones, and you can probably get most parts into position fairly easily. Possibly after some practice
Here is the news, I broke the canopy.......
So at this point I will not worry about cockpit look which I messed up to start with and just concentrate on the outside. :smiling:
Learned something the VERY hard way, just life.
Somone might ask, how the h...l did you do it?
Well, I was just dry fitting it and it seemed to be too narrow, so I tried to open it up.
The plastic parts from the sprue are much more flexible and can be deformed if overbend carefully so I thought the same will happen with the canopy. I was wrong! :tongue-out3:Comment
The broken canopy did not stop the fun. :smiling:
I wanted to paint a bit (airbrush newbie here as well) and I realized that the gun had to be removed from the bay for that. Removed it and broken it too. Reglued and it will be fine.Attached FilesComment
To try to paint the cockpit a bit, joystick had to be removed. Removed but machined off the bottom of the connection. Worked well. :smiling:Attached FilesComment
And FINALLY, it was time for the airbrush.
Love it. Finish is so much better than when paining by hand.
Lots of learning even for the first "real" painting time, no testing.
Made me setup for airbrush cleaning, better than first time but still needs lots of improvements. :tongue-out3: I am talking cleaning setup, using the airbrush is a totally different animal. :nerd:
I could not stop looking at the finish, so cool.Attached FilesComment
Clear polystyrene is brittle, the pigments in coloured polystyrene not only make it opaque but also more flexible. Aircraft canopies are probably the worst bits in this respect, because of their shape they tend to be easier to break accidentally than more or less flat pieces like car windshields, headlight lenses, etc.
Today, I was browsing thru supplies, hundreds and hundreds of them.... and a question popped up in me head.
Can you use Tamiya primer and then paint some Vallejo acrylic coats?
I am not even close to that stage, of course but I would love to know your opinions on that.
Another question, can I use acrylic paint (base coat) on non-acrylic based primers?
Just curious on all these things.Comment
Tamiya primer then Vallejo paint….Definitely yes! Done that hundreds of times. The grey Tamiya primer is far better than the white primer though. It adheres better.
Acrylic paint over non acrylic primer….again definitely yes.
I have used almost everything paint wise over almost everything else primer wise over the years with no issues as to compatibility. As long as the primer is allowed to properly dry then the overlying paint does not react.Comment
