Hasegawa 1/32 Junkers JU87D STUKA
  • Vaughan
    • Apr 2011
    • 3175
    Hi All
    Well I couldn't keep away so here's my next build. It's my first Hasegawa kit, another bargain from Modelzone, and all looks good so far. I've started with the office which is well detailed and a coat RLM66 is on.
    Vaughan
    [ATTACH]43439.IPB[/ATTACH]
    [ATTACH]43440.IPB[/ATTACH]
  • stona
    • Jul 2008
    • 9889
    Good choice! I've built a couple of these and it's a good kit. Having seen your Ar196 I can safely say this will be a walk in the park for you.
      • 18272
      Ah! I'll be watching this as well.
      You got that at a bargain price!
      • Vaughan
        • Apr 2011
        • 3175
        Hi would someone be able to move my thread to the planes and helicopter section.
        Thanks Vaughan
          Another big scale ,awesome! Looking forward to this build Vaughan.cheers Trey
          • Vaughan
            • Apr 2011
            • 3175
            The office is weathered with just the rear gunners seat and belts to add (I have just realised that I don't have any seat belts). The decals for the rear dials went down well, lots of decal soft was need but worked well. The office is a dry fit at the moment not sure wether to fit the side panels directly to the fuselage halves and then add the floor. Anyone have some ideas on this one?
            Vaughan
            [ATTACH]43592.IPB[/ATTACH]
            [ATTACH]43593.IPB[/ATTACH]
            [ATTACH]43594.IPB[/ATTACH]
            [ATTACH]43595.IPB[/ATTACH]
            [ATTACH]43596.IPB[/ATTACH]
            [ATTACH]43597.IPB[/ATTACH]
              :tongueout2:
              niceeeee choice and work so far my frined... VERY NICE INDEAD
              Like scheme says it goes directly to the fuselage and afterwards floor...
              I will do like this... I'm not shure, but seems to be a good way to do it because floor going underside sides panels into the pins of fuselage... and I think will fit ok...
              If I understand right your question?
              Roman
                I love the Stuka's! Fantastic work so far Vaughan, if your last build is anything to go by this will be a stunner!
                • saguy
                  • Feb 2011
                  • 570
                  looking forward to this ... have a soft spot for the ju87 ... very ugly looking bird but tons of character ........ nice looking cockpit ...rgds lindsey
                  • Vaughan
                    • Apr 2011
                    • 3175
                    Thanks for that Roman. It's not always obvious what to attach first but will give your idea a go.
                    Vaughan
                    • stona
                      • Jul 2008
                      • 9889
                      I think I did that too......but don't quote me!
                        • 22788
                        Nice looking office looking forward to the rest of the build
                        • Vaughan
                          • Apr 2011
                          • 3175
                          Hi All
                          The side walls are on. I've taken the advice of Roman and Steve on this one. A small area of the upper fuselage has to be trimmed to allow the canopy to fit properly. I had a look at the canopy at the same time all the framework is embossed on the inside, I've never come across this before, so the outside is completely smooth this wont make masking very easy as there's no frame to cut to. Does anybody have any ideas on this one?. It might be a case of ordering some canopy masks from Eduard although not cheap and I still need some seat belts.
                          Vaughan
                          [ATTACH]43601.IPB[/ATTACH]
                          [ATTACH]43602.IPB[/ATTACH]
                          [ATTACH]43603.IPB[/ATTACH]
                          [ATTACH]43604.IPB[/ATTACH]
                            Dont spend your money for that masking tapes... tamiya masking tape will do far enough... Of course if we are talking about canopy...
                            My way: Put masking tape a cross the canopy, from begining to ned to cover all (let me say) right side of canopy. Put canopy on source of light and cut on the edges of "panel lines" of canopy.
                            Just must be carefull when you do it... imageine that you are some brain suregery doctor LOOL
                            And of course these procedure is always done with me when I have magnifier glass on my head.
                            And must say... looks great so far
                            Roman
                            • stona
                              • Jul 2008
                              • 9889
                              I take it this kit doesn't come with the decals for inside and out then.
                              I masked mine in the usual way which was a fiddle as you've noticed. I also didn't paint the inside,just put the interior colour on the outside first in my normal way. That inner canopy framing is quite obvious on the real thing and there is a case for masking and painting the inside. If you did that I think masks would be a justifiable investment
                              An alternative,for the exterior anyway,is to use appropriately coloured decal film to represent the frames. Unless I'm mistaken some of the frames have the splinter demarcation on them making this option tricky too!
