Tamiya 1/32 F-16 (the big box )
  • Mickc1440
    • 4779
    I’ve been itching to make a start on this one but I’ve signed up for the Mosquito GB next month. I’ve decided to at least start the thread and see what I can get done. Firstly it’s a big box with lots of parts and extras that came with it. I’ve added some 3D cockpit decals and replacement wheel bays. Click image for larger version
    The inner lid is designed to hold the completed model if you’ve no display room. One of the parts boxes also doubles up as storage for the weapons which are interchangeable.
    Now for the sprues
ID:	1177652Click image for larger version
ID:	1177653Click image for larger version
ID:	1177654Click image for larger version
ID:	1177655Click image for larger version
ID:	1177657Click image for larger version
ID:	1177658Click image for larger version
    The kit came with two wheel options, the rubber ones in the kit and some AM weighted ones, not sure yet which I’ll use. The undercarriage is metal and there’s a nice metal nose weight to stop tail sitting. As you can see this is a BIG project for me so I don’t expect it to be finished quickly . Plenty of seats available and snacks will be provided for any rabble who drop by.
    • 18269
    I have a soft spot for the F16- which is fortunate as they fly over the house almost every day at the moment! (sometimes very fast and quite low!)
    Anyhow. I'm here for the long haul so be a good chap and put kettle on.
      • 18907
      Looks like a lot of plastic there Mick. I’m sure you’ll have great fun with it
      • scottie3158
        • 14201
        • Holbeach
        Mick,
        That will keep you put of mischief for a while. I will follow along.
          • 15702
          Hi Mick
          Certainly a lot of parts. Definitely one for the long haul.
          • BarryW
            • Jul 2011
            • 6027
            It’s a brilliant kit, perfect fit and great detail out of the box. One of the best Tamiya’s and hence one of the best kits around.
            The 3D set will go great with it, but I am not sure the replacement wheel wells will add anything.
            Enjoy.
            • stillp
              • 8093
              • Pete
              • Rugby
              Looks a nice kit, and with all that AM as well this is going to be a hell of a build!
              • langy71
                • 1950
                • Chris
                • Nottingham
                After seeing your excellent result with it's smaller brother, I'm in for this bad boy...
                • Mickc1440
                  • 4779
                  I've developed one for this aircraft after researching for the 1/48 build. Kettles on.
                  At the speed I build at least a years worth :hungry:
                  Mick,
                  Cheers Scottie glad to have you looking in
                  Enjoy.
                  I had to get the big brother to my 1/48 build and hoped it would go together as well. The wheel wells were going very cheap so I thought if I had them I could decide later so we shall see but welcome along.
                  Welcome to the build Pete, certainly going have to take my time with all these extra bits, bigger aircraft so nowhere to hide :smiling5:
                  Many thanks Chris let's hope so.
                  Thanks for taking the time to have a look and comment gents, looks like the kettles going to get some hammer.
                  • boatman
                    • Nov 2018
                    • 14478
                    • christopher
                    • NORFOLK UK
                    HI Mick m8 rabble member here as im in to lookin forward to the eats an drinks an seein this great kit go togeather pity as if it was me id light her up with nav an landing lights as this in my opinion brings the model to life an it would be easy to do on a big kit like this but you build it how you want an can i have a front seat before the rest of the rabble get here an sqabbilin begins lol an then there will be a call out to matron to sort them out lol
                    chrisb
                    • Mickc1440
                      • 4779
                      chrisb
                      Hi Chris and welcome along, not so sure about throwing electrics into the mix that's more for you more knowledgeable folk :smiling5:
                      • boatman
                        • Nov 2018
                        • 14478
                        • christopher
                        • NORFOLK UK
                        (Mick Qoute)
                        Mick what this wheight wheels ? then do you mean plastic ones whare they have a flat bulgey bottom as simulating the wheight of the aircraft ?
                        chrisb
                        • adt70hk
                          • Sep 2019
                          • 10409
                          Interesting Mick..... Not a small kit!
                          Good luck with the build!!
                          ATB.
                          • Mickc1440
                            • 4779
                            (Mick Qoute)
                            chrisb
                            Yes Chris they’re made to simulate the aircrafts weight on them
                            • Allen Dewire
                              • 4741
                              • Allen
                              • Bamberg
                              Evening Mick,
                              So you're gonna build the big size wing thingy of this bird now, huh.....Sure does have a whole bunch of parts to it, plus the AM stuff too. I looked at the destructions on Scalemates and figured you'll need a long time, if not longer to build it. I'm in Sir and wish you all the best in this endeavor.....Now go build a shelf big enough to hold it when you finish it.............
                              Allen
