Tamiya 1/32 F-16 (the big box )
First real glitch with the build and it’s causing me some serious head scratching. The spare ten minutes I had when I built the radar is now causing me some grief. The nose cone clips into a part to form a hinge allowing it to swing clear of the radar. The problem is it doesn’t allow the nose to close flush, this will then be a problem when I start to paint for obvious reasons. Unless I can try an modify the hinge it will be back to plan A and the nose cone will be glued on.
Assuming you are going to display this open Mick, then just pack the gap with damp tissue. It will dry hard and successfully mask the gap. Once you have finished painting just moisten it again and it will come off cleanly.Comment
Thanks for that Tim that’s definitely a new one on me. The original plan was shut but we’ll see. Thanks again thoughComment
A couple of minor updates, I’ve been doing some undercoating and while the parts dried I’ve added some final touches to the cockpit. After looking at some more reference pics I’ve added the remove before flight tags to the seat which just needs some orange paint adding and then added a piece of etch I’d left on the frame. It’s the yellow k shaped bit that is quite prominent in reference pics. Apparently it’s associated with the closing of the canopy, when pulled out it stops the pilots pushing the throttle forward with the canopy open. The canopy has to be closed and locked before it can be pushed back against the side wall allowing the throttle to be pushed forward.
Last quick update before I go on holiday. I made a start on putting together the bombs, missiles and fuel tanks. There’s also a jamming pod with some bits missing as it’s easier to paint that way. I really dislike putting cylinders together, there never seems to be enough guide pins to help with lining the two halves up. I’ve done the best I can with them but most still need cleaning up.
Lots of boom-booms there, Mick!!! They do look good as does the whole thang......Enjoy your holiday and see you when you get back Sir.
AllenLife's to short to be a sheep...Comment
