Tamiya 1/32 F-16 (the big box )
  • The Smythe Meister
    • Jan 2019
    • 6248
    #76
    Very nice additions there Mick
    Know what you mean about knowing when to stop..... It could end up being a never ending spiral !!
    • scottie3158
      • 14221
      • Holbeach
      #77
      lovely details Mick.
      • scottie3158
        • 14221
        • Holbeach
        #78
        • KarlW
          • Jul 2020
          • 1522
          #79
          I'm afraid any comments from me would be superflous, so I'll just like posts, if that's OK?
          • adt70hk
            • Sep 2019
            • 10429
            #80
            Mick,
            Sorry for behind on this. Love the additional touches you've added. That's coming on very nicely indeed. Very well done.
            • Mickc1440
              • 4779
              #81
              Very nice additions there Mick :smiling3:
              If I keep going it’s never going to get built
              Thanks pal, more of your inspiration
              Not a problem Karl thanks for having a look
              Originally posted by adt70hk
              Mick,
              Thanks Andrew, hopefully more to follow soon if I can focus
              • Mickc1440
                • 4779
                #82
                Not much more done but it’s definitely getting bigger. Joined the two halves of the upper fuselage. Bit of dry brushing after spraying the black and added a couple of etch plates, one being the builders plate and a tiny one on the canopy opening motor for effect.
                • Mickc1440
                  • 4779
                  #83
                  Had half an hour to spare so have joined the upper and lower fuselage. There are a couple of small areas to be filled but overall a really nice fit. I love the way these go together with no top and bottom seam. I put the main undercarriage struts on temporary for the pics, they need some brake lines adding before a permanent fix.
ID:	1183590Click image for larger version
                  • yak face
                    • Jun 2009
                    • 13855
                    • Tony
                    #84
                    Coming on great mick , looks a beautiful kit , cheers tony
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #85
                      THIS IS GOIN to look great Mick will carry on followin
                      chrisb
                      • Mark1
                        • Apr 2021
                        • 4156
                        #86
                        Looking really good so far.
                        • Mickc1440
                          • 4779
                          #87
                          chrisb
                          Many thanks gents, just need work to get out of the way then I can start to tidy it up and move on.
                            • 15746
                            Better and better Mick. Great details and all such neat work.
                            • Mickc1440
                              • 4779
                              #89
                              Built up the M61A1 cannon while i still wait for some detailing wire to arrive. It builds up nicely and I added some metal strips to the ammo feed and a couple of plugs and control cables to the breech area. Just a minor gripe now which I found too late to really rectify. I thought the gun and breach part both had removable covers to show it off. Turns out not and only the breach cover is. For some reason the gun tube part stops short leaving a gap as you can see in the pics. When completed only a small section of the barrels are visible when the cover gets glued on which is a shame, but the news from Poland is good, wire is almost here
ID:	1183753Click image for larger version
                              • scottie3158
                                • 14221
                                • Holbeach
                                #90
                                Mick coming on nicely mate.
