Tamiya 1/32 F-16 (the big box )
  • yak face
    • Jun 2009
    • 13854
    • Tony
    #121
    Great work mick , the additions to the undercarriage look excellent , really makes a difference . Decals look lovely too , good call on the blue fin scheme Cheers tony
    • Mickc1440
      • 4779
      #122
      Many thanks Tony. I'm just having a few issues with white paint and there's a ton of it in the undercarriage. My old favourite undercoat was a rattle can from GW but their new recipe is rubbish. It dries almost grey then had a reaction when I've airbrushed Vallejo Air white on it. Fortunately it's not too obvious so onwards I go
      • yak face
        • Jun 2009
        • 13854
        • Tony
        #123
        The GW stuff used to be fantastic - years ago my son used to do the warhammer figures and when he stopped I gained a load of his paints . They were superb , brushing lovely , great coverage and excellent colours ( though the names could be a bit mental - snot green , vomit brown , scab red !!?) then a few years ago they changed the formula and introduced all different types - base , glaze , wash , highlights . I tried a few but couldnt get on with them , whereas before they could just be used straight out of the bottle , now it was a multi stage layering process ,which I imagine is fine for figures but a little OTT if i just want to paint an undercarriage leg or an instrument panel.
          • 18932
          If you still want them Tony, apparently Coat D’Armes paint is the same stuff……
          • Mickc1440
            • 4779
            #125
            I used to game regularly and as you say the paints were great and yes I know times change but the whole thing just seemed to get over complicated along with the constant changing of rules and updating armies very regularly. I know they have to make money but the cost of some stuff now is eye watering :smiling:
              I think that’s the same paint as the one before the one before the one before the current GW line … That is, the same as in the old, narrow hexagonal pots, not the later, wider hexagonal pots with screw lids or those with flip-tops, never mind the paints that came after with all the different layering nonsense that makes it really hard to paint with.
                • 18932
                They have come out with contrast paint now so you are one behind Jakko. Supposed to replace the base and layer stuff in one coat……personally I just learned how to do it all with Vallejo model colour and a wet palette LOL
                  It’s been something like six years since my last 40K game, and years more since I played it frequently, so I’m not keeping up with what GW is doing these days at all
                  • The Smythe Meister
                    • Jan 2019
                    • 6248
                    #129
                    I wasn’t going to include the next bit of the model as I was going to secure the nose cone permanently but when you have ten minutes to spare
                    [ATTACH=CONFIG]n1184628[/ATTACH]
                    No way are you permanently covering that up Mick......
                    ...... Or I'll send the boys around !!
                    • Mickc1440
                      • 4779
                      #130
                      Ok Andy keep the boys on a tight leash
                      • Mickc1440
                        • 4779
                        #131
                        My book has come good again. My instructions state do not paint the etch my book says............
                        • Mickc1440
                          • 4779
                          #132
                          I have absolutely definitely finished detailing this cockpit. Hang on what’s this behind the seat. Chaff and flare programmer. Nope don’t need to do that.........oh go on let’s try then. It’s a bit rough yet but a bit of pewter and plastic and nearly there. Needs to be tidied up and then buried in paint
ID:	1184880Click image for larger version
                          • colin m
                            • 8770
                            • Colin
                            • Stafford, UK
                            #133
                            Great work Mick. Your build is compelling, I need to check in more often.
                            • Mr Bowcat
                              SMF OG
                              • Dec 2016
                              • 4608
                              • Bob
                              • London
                              #134
                              This is really coming together, great work Mick.
                              Si vis pacem, para bellum.
                              • Mickc1440
                                • 4779
                                #135
                                Thanks Colin you’re always welcome, another quick update now
                                Thank you Bob
