Looking very nice Tony.
Airfix Focke Wulf FW190 A8 1/72
RLM79 now on and masking taken off. The white band under the fuselage was partially unmasked before the rlm 79 was sprayed , on the actual aircraft the band was sprayed over on the top side . The green mottles were also sprayed in the field and in places oversprayed the balkenkreuz on fuselage and wings not to mention the swastika on the tail ( which isnt supplied on either the airfix or revell decal sheets anyway ) . To achieve this Iโm going to have to gloss the airframe at this stage and apply the decals before the mottle .
ATB.
AndrewComment
The balkenkreuz that needed fitting before I spray the green got fitted this morning before I went to work . Tonight theyve dried thoroughly so it was time to get the green blotches on .I turned the airbrush needle stop right in so there was only a fraction of movement and turned the air down a bit . The paint was thinned and a good few drops of flow improver added and off we went. I had to keep cleaning the needle tip and nozzle as the paint was drying on the needle and clogging but eventually got there . Ive assembled the prop and spinner / engine fan . The spiral on the spinner was a little short at the prop end so it was finished off with a touch of white .
The centreline bomb rack has been fitted and the black sections behind the exhaust have been painted . Next job is a gloss coat to seal in the green and then the rest of the decals - my guess is it looks like the camo was overpainted with the sand/green scheme after the aircraft was transferred from another unit then the unit specific markings were added after . Maybe this would explain why the balkenkreuz were painted round and oversprayed a little but the number and squadron emblem look like they were done after the green .Comment
